first swap need help!
Old Oct 8, 2010 | 11:51 AM
gs-r94coupe's Avatar
Default first swap need help!
i have a 94 civic dx coupe and i bought it as a shell, and bought a 95 b18c1 gsr for it. hooked up all my wires, hoses, grounds, ect and when i go to start the car it wants to start but it just wont turn over, so i checked the dizzy bought new ignitor and coil, still didnt work. so i thought it was a wire issue, i switched out the whole dash harness and still the same thing. i took out the spark plugs and there was no gas on them and wernt getting spark can anyone help me please!!??
Old Oct 8, 2010 | 12:22 PM
Eclectia's Avatar
Default Re: first swap need help!
Check your plug wires, and make sure your engine is getting fuel and air.
Old Oct 8, 2010 | 12:50 PM
my plug wires are brand new and its not getting fuel or air, butif i loosen mt fuel rail gas sprays out its just not getting to to spark plugs
Old Oct 8, 2010 | 02:50 PM
2kdrift's Avatar
Originally Posted by gs-r94coupe
my plug wires are brand new and its not getting fuel or air, but if i loosen mt fuel rail gas sprays out its just not getting to to spark plugs
it doesn't necessarily goto your "sparkplug". it does go into the cylinder. test that your injectors are getting a pulse. what do you mean its not getting air??? hows that even possible
Old Oct 8, 2010 | 03:46 PM
HondaPartsHero's Avatar
Technical Hero
What ECU? Any check engine lights? Does the check engine light come on for 2 seconds then cut off when you turn the ignition to accessory?
Old Oct 9, 2010 | 11:49 AM
how do you check the injectors?
and im running obd1 p72 ecu and the check engine light comes on but it for my v-tech cause i havent hooked it up yet, i wanna here it start before i wire the v-tech up
Boosted96gsr
Jan 9, 2012 08:04 PM
gs-r94coupe
Engine Management and Tuning
Oct 9, 2010 11:50 AM
milanoteg
Sep 12, 2009 08:35 PM
tuquikgsr
Dec 18, 2008 09:40 PM
94civicsally
15
Mar 18, 2004 09:50 AM
