1993 civic hatch
Old Oct 12, 2010 | 11:05 PM
pandaboyswagg's Avatar
Icon2 1993 civic hatch
i have a 1993 civic hatch and i would like to know what the fastest stock engine i could put in without replacing the ecu and wiring harness, i need something that will bolt right in.
Old Oct 12, 2010 | 11:31 PM
chewyv's Avatar
pm4nudes
Default Re: 1993 civic hatch
The one in your car.
Old Oct 14, 2010 | 11:23 PM
bluebomber's Avatar
Information Leafblower
/thread.
Old Oct 15, 2010 | 03:04 PM
96b18c's Avatar
DMC Flux capacitor
Old Oct 15, 2010 | 03:06 PM
96b18c's Avatar
JK, Just a stock one is about as good as it'll get without changing those two. Why isn't that an option?
Old Oct 15, 2010 | 04:36 PM
noz79's Avatar
You can put anything you want in there. You can do it if you chip your current ecu and have it tuned to whatever motor you put in it. Youll have to run some extra wiring for vtec if you go that route. The si/ex wiring harness will make it easier though.
Old Oct 18, 2010 | 07:49 AM
its just gonna be a daily driver and i dont feel like ripping the whole wiring harness out
Old Oct 18, 2010 | 10:54 AM
96b18c's Avatar
I see. Well then stock with a greddy turbo kit is a fun setup for a daily.
Old Oct 18, 2010 | 11:09 AM
nemisish20's Avatar
Wheres my titleeeee!
The 1993 if it is pre june of 1993, the shock tower plugs are wired for VTEC.
You could go with a B16,GSR,ITR,H22,H2B, all on that harness, you will have to make few modifcations if you go with an H series (Extend charge harness because of front mounted alternator) and if you go with a B series vtec, you just need to wire the VTEC wires to the shock tower.
The ECU will always have to be changed with the engine but changing the ecu is as simple as pulling 3 plugs.
If you go with a GSR swap, get an aftermarket intake manifold because the factory D15 harness will not have any way to run the IAB's unless you wire them to the GSr ECU.
Usually when you purchase an engine swap, the engine harness will be included so you dont even have to pull the harness off our your D series. Most honda swaps are plug and play.
pandaboyswagg
Oct 12, 2010 11:47 PM
rcbamm
Oct 9, 2009 12:04 PM
steroidguy
May 7, 2004 11:32 AM
jdmjopey
May 1, 2004 10:21 PM
