waht kinds of bars???
Old Jan 2, 2003 | 11:09 AM
sslude's Avatar
Default waht kinds of bars???
can someone name all the "bars" ie. sway bar, strut bar, stabalizer bar..ect. caould you list them and waht they do or give a website. any information helps.
Old Jan 2, 2003 | 12:51 PM
PupaScoopa's Avatar
Default Re: waht kinds of bars??? (sslude)
A very simplified view:
Sway bars: kind of like a spring that will prevent one side of the suspension from moving excessively in relation to the other side. This helps control weight transfer so you don't overload a tire at any corner causing it to slide.
Strut bar: Binds the top of the damper towers to minimize their movement. This stiffens up the chassis.
Lower tie bar: attaches to the left and right lower control arm mounting points insuring that they don't move in/out during a drive.
I think I have a suspension tech .pdf file on my website:
http://webpages.charter.net/pupascoopa in the "car" section if I remember correctly. Hope this helps!
Old Jan 2, 2003 | 01:19 PM
sslude's Avatar
Default Re: waht kinds of bars??? (PupaScoopa)
anyone else? thanks for your help, i am going to check out that site right now
Old Jan 2, 2003 | 03:17 PM
t0p_sh0tta's Avatar
He basically covered everything. What else do you want to know?
Old Jan 2, 2003 | 03:55 PM
sslude's Avatar
Default Re: waht kinds of bars??? (t0p_sh0tta)
stabalizer bars..
Old Jan 2, 2003 | 08:39 PM
t0p_sh0tta's Avatar
They all fall under that category.
Old Jan 3, 2003 | 01:23 AM
texan's Avatar
While they do help control weight transfer they certainly don't limit it or prevent tire overload due to this, they in fact enhance load transfer and, on fwd cars, generally function to limit traction at a single axle, not optimize it. A swaybar equipped car sees more loading to the outside tire than it otherwise would, but the offset in limited chassis roll and attendent alignment change is generally enough to still show benefit (to a point). Stiffer swaybars generally make the driver feel better, but do little for the car's real performance if their purpose is something other than balancing out front to rear weight distribution under cornering loads.
Unseen Racer
Nov 8, 2008 01:33 PM
thambi23
Mar 13, 2008 05:15 AM
92integra-R
Apr 3, 2007 08:21 PM
93b20z
Suspension & Brakes
May 3, 2005 09:45 AM
