code 23 and coolant problems?? very worried.
Old Jan 3, 2003 | 11:07 AM
tbkonwso's Avatar
Default code 23 and coolant problems?? very worried.
my car 2000 honda civic ex
me and my friend just finished swaping a 99 intake mainfold on my car. we had the gasket from a 2000 civic ex (new) but only differce is there was a lil too big on the top part. so we cut off the top part and everything else matched perfectly.
Now my car is getting a code 23, knock sensor, and im draining a **** load of coolant and i dont notice any leak. i can drive 20 min and my coolant would get drained up completly. Car drives fine heres some stuff people told me that might be causing the problems. and i just want your thoughts and opinions on this.
1:Wrogn head gasket used or reused.
2:Air preasure build up inside the coolant lines.
3:Coolant going into the tranny causing knock sensor off.
Old Jan 3, 2003 | 11:17 AM
CHEETAH's Avatar
Default Re: code 23 and coolant problems?? very worried. (tbkonwso)
which motor ? GSR, B16a, ITR ? did oyu wire up the KS ? or are you using a GSR or ITR or civic Si ecu with your stock EX motor (which doesn't have a KS) ?
coolant leak, check all hoses after get gets hot, keep car where there is dry ground so you can spot it ... even with blown HG you can't lose all coolant ...
greg
Old Jan 3, 2003 | 12:12 PM
tbkonwso's Avatar
Default Re: code 23 and coolant problems?? very worried. (CHEETAH)
its a d16y8 civic ex engine.
Old Jan 3, 2003 | 04:27 PM
0554's Avatar
it could also be water pump. i know when my gasket went out on that and it leaked alittle bit of water that mine flashed that code
Old Jan 3, 2003 | 08:33 PM
CHEETAH's Avatar
which ecu ? that engine doenst have a KS ...
greg
trainergames
11
Oct 27, 2015 11:03 AM
jp520
Jan 14, 2013 01:22 PM
D'rae
Nov 4, 2012 04:43 PM
hondaville
Jul 11, 2008 05:32 PM
apr233
Mar 31, 2007 09:14 AM
