civic and Integra pedal assemblies
Old Jan 3, 2003 | 09:20 PM
Boosthead's Avatar
Default civic and Integra pedal assemblies
Does anyone know of teh civic and integra pedal assemblies are the same or will work? I have a buddy doing a B18 swap into a civic, converting the civic from auto to manual trans.
Old Jan 4, 2003 | 02:25 AM
chad174's Avatar
Default Re: civic and Integra pedal assemblies (Boosthead)
whoa dude, i'm doing the same exact thing to a 89 crx dx. 92 teg b18a1 w/obd-0 conversion(92-93 had a better powerband, more horses). but anyway, i just dropped the steering columns on both cars, and i've got the assemblies out, but havent attempted to put the teg one into the crx yet. i'm going to attempt it in the morning, its 2.24: am here in alaska, and about 10 hours from now, i'll let you know...good luck with your swap...also, maybe another questionm back at you...those 2 small vacuum canister-looking things on the back of the motor...what sensor is it that is attached the them? its a 4 pin connector. and do you know what plugs into the 8-pin plug that a connector from the dx harness was plugged into? it's got white grease all over on the inside. sorry for all the questions. good luck.
5thGenFanatic
Nov 26, 2007 12:07 PM
na300z
Mar 24, 2005 09:11 PM
b16pwrcrx
Sep 9, 2004 04:30 PM
