GSR head on ITR block
Old Dec 31, 2002 | 08:17 AM
Alpha_GSR's Avatar
Default GSR head on ITR block
What's the compression ratio going to be? Also, I was wondering if this would effect smog? Thanks.
Kong
Old Dec 31, 2002 | 09:38 AM
Spade's Avatar
Default Re: GSR head on ITR block (Alpha_GSR)
Smog = Illegal if the smogger knows what he is doing.
http://www.c-speedracing.com for comprssion.
I wouldn't switch the head unless I had to.
Old Dec 31, 2002 | 11:49 AM
PupaScoopa's Avatar
Default Re: GSR head on ITR block (Spade)
CR will probably be very similar. You'll lose power because the ITR head is hand-ported at the factory, and the GSR head/intake mani uses a two-stage VTEC crossover; so it'll feel a little more suble when the big lobes are engaged.
Old Jan 1, 2003 | 08:18 AM
Alpha_GSR's Avatar
Default Re: GSR head on ITR block (PupaScoopa)
Well the reason why I want to use the head is because it has been ported by Portflow, with racing valves, valve springs and retainers, S2 manifold, Cams & Sprockets, along with a ported TB.
Do you guys think this will be a good setup?
Old Jan 1, 2003 | 08:21 AM
eg6ajk's Avatar
actually a friend of mine had a simliar setup running JUN III cams, he made over 200whp. same head later went to another motor (b16a) with Spec Bs it made close to 190whp in the car.
ported GSR head flows well, there should be no problems in using it. as far as c/r its going to be about 10.8-10.9 (USDM) or 11.2-11.3(JDM block)
X2BOARD
Apr 18, 2013 07:43 PM
tempsohc
Jun 30, 2011 07:05 PM
X2BOARD
Apr 27, 2005 12:09 PM
Kelvin96GSR
May 26, 2003 11:13 PM
memphiss13
Apr 8, 2002 12:02 AM
