Best Adj. Cam gears
I'm just curious what people think is the best choice of adj. cam gears. I have heard of a few that slip, strip & are also hard to read the marks on. Anyone have any comments?
Thanks ahead.
Thanks ahead.
I use the AEM's and have used the same set for three years . I replaced the bolts that AEM uses with some grade 8 bolts that have a better head on them. The bolts that come with the gears are kind of easy to strip (the allen head portion). Other than the bolt head issue, the AEM's are great. I have heard from reliable sources that the Skunk2 gears have a problem with the timing mark etchings-i.e. the marks are off. If you are dyno tuning, that won't be a big issue because the tuner will find the best settings anyway. Stick with name brand and you should be o.k. Just depends on your wallet and your taste as to which gears to buy.
I was thinking about AEM, but wasn't sure. I had heard of a few problems with them like bolts stripping and the gears slipping, but I do know that they have put out a newer set that was supposed to fix them.
thanks for the info.
Thanks for the info.
