Question about Piston rings, order of installation
Old Jan 2, 2003 | 01:52 PM
275Performance's Avatar
Default Question about Piston rings, order of installation
I have a set of Wisco/Endyn pistons.
Ring set has four rings:
gold (looks like copper) ring
two thin black rings
and one thick black ring
oil ring
I installed the oil ring already
There are three grooves still in the piston. What order do the rings for from top to bottom. Thanks a lot.
Old Jan 2, 2003 | 03:22 PM
Kataku2K3's Avatar
Default Re: Question about Piston rings, order of installation (TDCPerformance)
first groove - TOP = first compression... (the thickest one)
second groove - SECOND = second compression... (a bit thinner than the first)
third groove - BOTTOM = first oil ring spacer (the thin one), next in the same groove = oil ring, next also in the same groove = second oil ring spacer (the other thin one)
Remember to offset each ring 90 degrees from the other ... Good Luck
[Modified by Kataku2K3, 4:26 PM 1/2/2003]
Old Jan 2, 2003 | 03:49 PM
Default Re: Question about Piston rings, order of installation (Kataku2K3)
thanks A LOT thats just what I needed to know
Old Jan 2, 2003 | 04:51 PM
IN VTEC's Avatar
I can't remember the orientation, but the top two rings (or is it just teh top compression ring) have up/down orientation. One side has to face up to properly seal as the piston travels up/down.
Also, never place the ring gaps on thrust sides.
LOVEthatDC2
Aug 7, 2009 11:06 AM
N20civicB18
Oct 25, 2004 06:55 AM
Aeka GSR
Sep 28, 2003 11:15 AM
Islander
Oct 11, 2002 02:45 AM
