Could someone interpert this for me?
Old Jan 1, 2003 | 02:06 PM
2001civ's Avatar
Default Could someone interpert this for me?
EDIT:The pictures are up, scroll down
This is my first time posting pics sorry if they don't work
[Modified by 2001civ, 3:59 AM 1/2/2003]
Old Jan 1, 2003 | 02:50 PM
_BEN_'s Avatar
Default Re: Could someone interpert this for me? (2001civ)
Are the pictures still in your storage bin?
If so you need to make an album and put them in there.
Then you can link them
Old Jan 1, 2003 | 04:33 PM
2001civ's Avatar
[Modified by 2001civ, 6:34 PM 1/1/2003]
[Modified by 2001civ, 6:41 PM 1/1/2003]
Old Jan 1, 2003 | 04:44 PM
2001civ's Avatar
Ok got them up. I got this done at firestone. I am THE WORLDS WORST SUSEPENSION PERSON. can anyone fill me in on how to read this, I asked them but they were really shady about it.
Old Jan 1, 2003 | 06:36 PM
slvrcivic97's Avatar
Pictures still are not working I'll try and help you out when you get them up
Old Jan 1, 2003 | 06:48 PM
VTEC-DA's Avatar
Old Jan 1, 2003 | 08:08 PM
2001civ's Avatar
Default Re: Could someone interpert this for me? (VTEC-DA)
Thanks for getting those up VTEC-DA.
Old Jan 2, 2003 | 08:18 AM
2001civ's Avatar
Sorry they are sloppy, they were scanned and shrunk
Old Jan 2, 2003 | 08:45 AM
RaceTilIDie's Avatar
It looks like they did as little work as possible to get your alignment into factory spec. That's all most of those places can do anyways. The question is this: what good is rear wheel thrust angle on a front wheel drive vehicle?
Old Jan 2, 2003 | 09:00 AM
b19coupe's Avatar
Default Re: Could someone interpert this for me? (RaceTilIDie)
You don't want any rear wheel thrust angle-it means the rear wheels are turning one way or the other. 0 degrees is ideal. It does not matter if the vehicle is FWD or RWD.
Old Jan 2, 2003 | 09:12 AM
Default Re: Could someone interpert this for me? (b19coupe)
I know on RWD cars, it helps get better traction and to track straight.
Old Jan 2, 2003 | 10:01 AM
2001civ's Avatar
Is the camber and toe ok or does that need to be fixed? How do I read those numbers?
Old Jan 2, 2003 | 10:40 AM
The pics are gone again. I think the toe was OK, but the camber #'s were different between left and right. They were in spec, but not the "best" they could be for performance or tire wear. Also, those are factory specs, if you want better handling you can increase negative camber, but at the expense of faster tire wear. This is normally called a performance alignment, but you should get it done somewhere that knows what they are doing.
Old Jan 2, 2003 | 11:20 AM
2001civ's Avatar
I was wondering how the factory specs would change it. Thank everyone, I'm going to ask them to do it right or give my money back.
mafay2
Sep 21, 2010 02:12 PM
whatcivic
Sep 30, 2005 12:59 AM
mrDFWmechanic
Jan 18, 2005 10:15 PM
eh2 nihonjin
Oct 7, 2003 09:14 AM
SLoWEk
Jun 5, 2003 10:04 PM
