Timing belt install, TDC problem
Old Jan 2, 2003 | 04:48 PM
Kamin's Avatar
Default Timing belt install, TDC problem
Ok im changing my tbelt and tensioner and ive run into a snag.
this is from c-speed's install for a timing belt
i dont have a mark like that.
i have a dot made by a green marker, and 2 small notches on the outside of the crank gear about 1/5 of an inch apart.
if i line up the mark on the oil pump with the green dot then put the crank pulley on, it dosent line match the mark on the lower timing belt cover.
im so confused...
oh duh, second gen b16 engine.
[Modified by Kamin, 5:50 PM 1/2/2003]
Old Jan 2, 2003 | 04:54 PM
Kamin's Avatar
Default Re: Timing belt install, TDC problem (Kamin)
nevermind
im a dumbass.
forgot to remove the little cover for the gear.
damn i feel stupid lol.
Old Jan 2, 2003 | 05:13 PM
Shawn C's Avatar
In The Garage
ha ha... you got it. go drink a beer. that always helps. but sometimes you have parts left over. although they say if you dont have parts left over, you didnt do it right. oh well
Old Jan 2, 2003 | 06:19 PM
Kamin's Avatar
Default Re: Timing belt install, TDC problem (22lbGS-R)
lol
well the engine is out of the car with no transmission, im probably gonna have some parts left over when i done
but for now it looks like i have everything...so far.. hehehe
TorquelessB16
May 24, 2006 12:33 PM
VTgringo
Aug 11, 2004 03:47 PM
SpoonFedHatch
Nov 13, 2003 08:23 PM
SpoonFedHatch
Nov 13, 2003 08:01 AM
