Second gen b16 alternator
Old Jan 4, 2003 | 01:18 PM
Kamin's Avatar
Default Second gen b16 alternator
Im replacing the alternator from my second gen b16, I just went to autozone and bought one for a 94 del sol vtec and it dosent fit, arent all the b series the same?
Old Jan 4, 2003 | 01:23 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Second gen b16 alternator (Kamin)
the plug or the mount doesnt fit?
Old Jan 4, 2003 | 01:26 PM
Kamin's Avatar
Default Re: Second gen b16 alternator (Blaze45)
if i put the bottom bolt in, the top dosent line up to the bracket, its like 1/4 inch too tall and it wont slide all the way forward because it hits the bolt for the upper timing belt cover.
[Modified by Kamin, 2:26 PM 1/4/2003]
Old Jan 4, 2003 | 01:43 PM
B20Monster's Avatar
did you make sure to clarify if it was a SOHC or DOHC at Autozone? if anything.. you might have better luck ordering an integra alternator.. just make you got the right plug type.. od0..od1.. obd2.
Old Jan 4, 2003 | 01:48 PM
Kamin's Avatar
Default Re: Second gen b16 alternator (B20Monster)
um yes i ordered the one for the dohc vtec del slow motor. and the same type as my stock one (nippon denso)
Old Jan 4, 2003 | 02:36 PM
Kamin's Avatar
ok story is the JDM bracket is diffrent from the USDM del slow b16 bracket, a GSR alternator works great just installed it.
d1nki
Dec 11, 2006 06:23 PM
Mugencrxsir1
Sep 10, 2006 02:28 PM
RCautoworks
Jan 15, 2003 05:55 PM
FBPninetynineEM1
Oct 15, 2002 10:53 PM
Monty
Jun 4, 2002 01:41 PM
