CTR pistons in GSR... Few questions ?
Old Jan 4, 2003 | 01:05 PM
SIReg9's Avatar
Default CTR pistons in GSR... Few questions ?
Alright, ive got a GSR And the heads been milled, but i duno how much, and its also been cut for 0.5 oversized valves. The question is...Is the dome on the pistons too high, and will it hit? Ive put the pistons on the head and it looks like it will fit, But i just wanna make sure before i put all the stuff together. Thanks for any help.
Old Jan 4, 2003 | 01:46 PM
B20Monster's Avatar
Default Re: CTR pistons in GSR... Few questions ? (SIReg9)
the dome on the piston should fit depending on how much was milled off the head. with a gsr.. that's gonna be one high compression motor.
Old Jan 4, 2003 | 02:22 PM
Kataku2K3's Avatar
Default Re: CTR pistons in GSR... Few questions ? (B20Monster)
Toss the head on... Lock the VTEC rockers in the #1 cylinder and clay the motor... That's ur best bet on knowing... Good Luck
Old Jan 4, 2003 | 05:03 PM
b19coupe's Avatar
If the head was milled only .010 and you use a stock head gasket, compression will be 12.4 : 1. Clay the motor, especially if you are using bigger than stock cams.
Old Jan 4, 2003 | 10:32 PM
94TealGSR's Avatar
Default Re: CTR pistons in GSR... Few questions ? (b19coupe)
http://www.c-speedracing.com/howto/claymotor/clay.php
ls_bitik
Aug 9, 2007 08:22 AM
. WAAS_SAPPENING
15
Jun 12, 2006 06:51 PM
devoxtekxhb
Oct 4, 2002 06:22 AM
X2BOARD
May 29, 2002 05:40 PM
