Which bolts need lock tight on clutch install?
Re: Which bolts need lock tight on clutch install? (ActiveAero)
no.........some guys like to put some on all the bolts............i never had a problem with bolts comeing loose once torqued down........
it doesnt say anything in the helms manual about applying anything to the threads so i dont bother...
Re: Which bolts need lock tight on clutch install? (non-VTEC)
no........
Apply red loctite to the pressure plate bolts and pray you never need a new clutch.
J/K. Just torque the bolts to spec and you will be fine.
Re: Which bolts need lock tight on clutch install? (salbaje)
Why wouldn't you put loctite on the bolts???? I put red loctite on all my flywheel and clutch bolts.
Re: Which bolts need lock tight on clutch install? (smokin rubber)
I use Permatex red on both too... I dunno it's just the way i've always done it... Red is a pain in the *** to get loose later on but it's good if you don't want the bolts to vibrate loose... hehe... red and 76ft/lbs. for the flywheel and red and 19ft/lbs. for the PP... Latez
GSR936
32
12-07-2008 08:42 AM
jdm_vtec
12-06-2006 07:50 AM
crxgurlllll
11
12-10-2002 09:23 AM
