Valve adjusment
Old Jan 4, 2003 | 03:21 PM
one pnt 6 hatch's Avatar
Default Valve adjusment
I need to know what to adjust my valves too. i have a 90 integra LS. they are tapping like a bitch.
Old Jan 4, 2003 | 04:54 PM
b19coupe's Avatar
Default Re: Valve adjusment (one pnt 8 hatch)
.017mm intake and .019mm exhaust.
Old Jan 4, 2003 | 09:07 PM
Default Re: Valve adjusment (b19coupe)
aight i did that and now it runs like a friggin go kart. its sputters and sounds like a 2 cycle at idol and has lost all of its power and alomst stalls when i let out the clutch. now what in de hell is wrong with it?????????????????????????????????????
Old Jan 4, 2003 | 10:12 PM
HookUpsImportTek's Avatar
You have adjusted them wrong. I would suggest taking your vehicle to the nearest honda/acura specialist or dealer to check your job and/or make the necessary adjustments. -HIT
Old Jan 4, 2003 | 10:19 PM
RAWB's Avatar
Default Re: Valve adjusment (HookUpsImportTek)
Did you put the sparkplug wires back on right?
Old Jan 4, 2003 | 11:37 PM
IN VTEC's Avatar
THey should be tighter than that.
The non-VTEC motors run tighter valve clearances.
Old Jan 5, 2003 | 12:12 AM
b19coupe's Avatar
Default Re: Valve adjusment (IN VTEC)
B18A are .017mm and .019mm, just like the VTEC motors.
B18B valve lash is .010mm and .018mm.
Old Jan 5, 2003 | 07:52 AM
97accordex's Avatar
Silly question but,,,,,,,,,,
did you rotate each cylinder to TDC before adjusting its valves?
[Modified by 97accordex, 11:52 AM 1/5/2003]
Old Jan 5, 2003 | 07:58 AM
t0p_sh0tta's Avatar
Default Re: Valve adjusment (97accordex)
http://www.C-SpeedRacing.com check out the how-to section.
Old Jan 5, 2003 | 08:29 AM
Pengo's Avatar
Default Re: Valve adjusment (t0p_sh0tta)
why dont u tell us how u did it and and we'll let u know if u did anything wrong
Old Jan 5, 2003 | 01:02 PM
RaceTilIDie's Avatar
Not silly, I've seen it done.
Old Jan 5, 2003 | 02:25 PM
Pengo's Avatar
Default Re: Valve adjusment (RaceTilIDie)
yea, and make sure you're not only rotating them to TDC, but that your actually working on the cylinder thats currently at TDC. people make mistakes and forget. it happens
Old Jan 5, 2003 | 02:27 PM
Kamin's Avatar
Default Re: Valve adjusment (Pengo)
thats what my money is on
(he didnt rotate the crank)
Old Jan 5, 2003 | 04:13 PM
Default Re: Valve adjusment (Kamin)
no i rotated the crank made sure each cylinder i adjusted was on TDC of the inake stroke. and i adjusted them right. i found out what i did wrong. plug wires were on wrong.
Old Jan 5, 2003 | 04:38 PM
RAWB's Avatar
Happens to the best of us
Old Jan 5, 2003 | 05:45 PM
smokey2.0's Avatar
did you adjust them, according to the engine's fireing order!
Old Jan 5, 2003 | 06:24 PM
Default Re: Valve adjusment (smokey2.0)
i adjusted them 1 3 4 2 and i think thats the firing order
[Modified by one pnt 8 hatch, 3:25 AM 1/6/2003]
Old Jan 5, 2003 | 06:27 PM
smokey2.0's Avatar
yes, that's correct. bring #1 cyl to tdc, and adjust both intake and exhaust valves, then tdc #3cyl and adjust, tdc # 4cyl and adjust, tdc # 2 cyl and adjust. good luck!
[Modified by smokey2.0, 9:31 PM 1/5/2003]
Old Jan 5, 2003 | 08:06 PM
ya i did that. i adjusted them to .017 intake and .019 exhaust but they still seem to be tappin. anyone got anyclue why????????
Old Jan 5, 2003 | 09:30 PM
87sivtec's Avatar
Are you sure it's not your fuel injectors clicking?
W!d3b0dYr3X
Feb 23, 2012 12:20 PM
mike614keu
Jan 14, 2007 07:17 PM
petergriffen
Jul 19, 2006 07:27 PM
94B18B1Teg
Nov 26, 2003 10:33 PM
GreenMachine
Jan 14, 2002 04:01 PM
