stock shocks
Old Jan 2, 2003 | 11:14 AM
lazy bum shaughn's Avatar
Default stock shocks
How do your stock shocks blow out? I hear people say that the spring rate of their new springs effect the shocks, how?
Old Jan 2, 2003 | 01:17 PM
PupaScoopa's Avatar
Default Re: stock shocks (lazy bum shaughn)
A stiffer spring can store more energy in a shorter distance of compression. Take for example two springs, one has a rate of 100lb/in the other 400lb/in. On the first, for every 100lb you exert, it will compress 1inch. You need 400lb to compress the second spring 1in. Those springs will releast 100lb and 400lb (respectively) as it decompresses that 1in distance.
Stock damper cannot control this higher amount of energy. The oil is pushed through the orfices in the damper too fast when the spring rate is higher. Eventually, something has to blow. Usually it's a seal that was only designed to contain a certain amount of pressure.
02 accord
Suspension & Brakes
18
Jan 28, 2013 12:56 PM
Type_D
Dec 24, 2009 09:42 PM
CRISIS
Suspension & Brakes
Jun 11, 2006 08:47 PM
CRISIS
10
Jun 10, 2006 09:46 PM
WangChung
Jul 17, 2003 01:55 PM
