Emissions help
Old Jan 2, 2003 | 08:54 AM
raene's Avatar
Default Emissions help
I've got an emissions test coming up.
What can I do to clean up the emissions? New plugs, cleaning the air filter, running higher-octane gas (will this help?), injector cleaner, leaning out the mixture a little & lowering the idle...
Any suggestions?
Old Jan 2, 2003 | 09:02 AM
RaceTilIDie's Avatar
Default Re: Emissions help (raene)
Any suggestions?
New plugs, cap, rotor, air filter. Change oil and oil filter. Adjust timing, get idle to spec. RUN LOWER OCTANE GAS! And most importantly get the car HOT, the Cat only works when hot.
Spade's Avatar
RUN LOWER OCTANE.....I hate that bad rumor.
Higher octane doesn't burn completly
Run the lowest you can, check your plugs, check your plug wires and make sure they are on properly, take off your throttle body and clean it, clean the inside of the intake manifold as much as you can, run the car around for about 30 minutes or so before you go to the smog station, don't shut off the car when you get there leave it running to keep the Catalytic converter hot.
One misfire while getting smogged and it's over.
Old Jan 2, 2003 | 01:37 PM
Malgerus's Avatar
Default Re: Emissions help (Spade)
methyl hydrate
Old Jan 9, 2003 | 02:31 PM
all stock's Avatar
Default Re: Emissions help (Mr. S)
at an autostore they sell some stuff that guarantees u to pass or something. it's an octane lowerer. just dump it in ur tank and ur good. as far as emissions.
cyotani
10
May 8, 2013 07:47 PM
SIC-CIVIC
12
Oct 25, 2007 08:43 PM
IVI
Dec 13, 2005 10:12 AM
sleepyhamsterlx
Oct 4, 2003 01:53 PM
mickey513
Apr 7, 2003 10:30 AM
