Weird timing bellt noises
Old Jan 1, 2003 | 12:13 PM
Big Teggie's Avatar
Default Weird timing bellt noises
I just installed some cam gears, and adjusted the timing belt. It makes noises now. When i rev the car up, it its makes a whining noise, like a superchager or something. It is coming from the timing belt area. I am thinking the belt may be too tight. When teh car idles, you can hear sort of a grind every now and then by the timing belt area. Should I just loosen the tension a bit? I dont know what to try. Anyone ever experience this?
Thanks
Old Jan 1, 2003 | 02:55 PM
_BEN_'s Avatar
Default Re: Weird timing bellt noises (Big Teggie)
Ive been told that if it makes that noise that its too tight. Try loosening it a smige and see if that solves it.
Old Jan 1, 2003 | 05:06 PM
Passaudi1.8t's Avatar
New User
Default Re: Weird timing bellt noises (nosepkr)
The same thing happened when I had an AEM cam gear and new timing belt installed on my old Civic with a D16z6... it had to do with the timing belt not sitting in the cam gear grooves perfectly. It went away after a couple thousand miles of driving, once the teeth seated perfectly in the grooves. Don't sweat it.
Old Jan 1, 2003 | 07:14 PM
TodaSi's Avatar
Default Re: Weird timing bellt noises (vtecivicex)
More often or not, if it's a wirrrrr sound like you discribed, your belt is too tight.
Old Jan 1, 2003 | 11:19 PM
Big Teggie's Avatar
Default Re: Weird timing bellt noises (TodaSi)
It must be too tight, I am gonna give it some slack tomorrow. Ill see what happens.
Old Jan 2, 2003 | 12:10 AM
Kamin's Avatar
be SURE you dont loosen the tension too much, you dont want to skip a tooth on a cam gear.
the flex is supposed to be ~1/2 inch in the timing belt.
Old Jan 2, 2003 | 12:28 AM
Type Wah's Avatar
Its just VTEC yo!!!!!
Old Jan 2, 2003 | 04:47 AM
tmg's Avatar
tmg
yeah, that happened to me as well when i changed my gear and belt but it only happened when the car wasn't warmed up. it may not even be the timing belt, check the alternator and ac compressor belts too.
b16-ef-si
May 16, 2009 03:23 PM
verycleanhatch
Jun 20, 2006 05:29 PM
strsi
15
Nov 8, 2005 07:59 AM
ef8mugen
Oct 3, 2003 09:14 PM
slooogsr
Sep 30, 2003 12:24 PM
