VAFC Throttle Position Settings
Old Jan 2, 2003 | 04:04 PM
98R-1144's Avatar
Default VAFC Throttle Position Settings
What exactly does this do? The manual is pretty unclear (to me at least).
I don't plan on messing with it.. .just trying to figure out what it means.
It's still set to stock settings: 10% LOW and 50% HI.
Does it mean anything 10% < X < 50% is LOW, and anything > 50% is HI?
On the same page in the VAFC manual (pg 34), it mentions something about the Wide/Narr. Thr correction %... what exactly does that mean, and how do you even change these correction values?
Old Jan 2, 2003 | 04:07 PM
87sivtec's Avatar
Default Re: VAFC Throttle Position Settings (98R-1144)
Throttle correction values as I understand them are to correct fuel rate on a load basis. Load being measured as part throttle and wide open throttle. This being not rpm specific though.
Correct me if I am wrong.
Old Jan 2, 2003 | 05:37 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: VAFC Throttle Position Settings (87sivtec)
do you even know what your VAFC does? =P
sounds like a whim buy
Old Jan 2, 2003 | 07:25 PM
98R-1144's Avatar
Default Re: VAFC Throttle Position Settings (dLo GSR)
uh yes i know what it does. it adjusts the fuel at selected rpm points.. as well as change the vtec xover point.
and this was already done via a dyno. just because i'm wanting to understand every feature of the vafc doesn't mean i dont know what it basically does
EDIT: Their website gave a more detailed explanation of what it does. It's essentially the same thing as using adjusting the fuel map, but the correction values allow finer tuning.
[Modified by 98R-1144, 8:29 PM 1/2/2003]
HondaH22a#1
Aug 16, 2007 06:50 AM
toooslow
Oct 9, 2005 05:59 AM
CPR
Oct 2, 2002 10:37 AM
IgniteTeg
Apr 26, 2002 07:55 AM
IgniteTeg
Apr 25, 2002 11:25 PM
