Hydro clutch problems, please help!
Old Dec 30, 2002 | 11:43 PM
integls95's Avatar
Default Hydro clutch problems, please help!
last week my car wouldn't shift into gear, there wasn't enough pressure for the slave cylinder to push the fork, so I replaced that and nothing. Today I bought a new clutch master cylinder took out the tranny even to check out if the clutch or release bearing is messed up, nothing at all. I installed and same thing not enough pressure to the slave cylinder and I bleed it good, not even one bubble. what do u think the problem is? I'm not getting enough pressure to the slave cylinder and I did replace the mastercylinder and the slave cylinder, help me out please thanks
Old Dec 31, 2002 | 07:22 AM
Crazydave's Avatar
Default Re: Hydro clutch problems, please help! (integls95)
you have already replaced master cylinder and slave clyinder?
keep bleeding it!!!!!!!!!! get a vacuum bleader
run the car for a few minutes (to vibrate it) and bleed again
make sure to keep the resevoir FULL
check the line & replace if necessary
Old Dec 31, 2002 | 07:31 AM
Nameless RB26's Avatar
Default Re: Hydro clutch problems, please help! (Crazydave)
So I'm guessing you have looked at the slave cylinder when you were pumping the clutch? Or did a friend help you?
If it really isn't moving like you said, then I'd check the lines. Bleed them to death.
Old Jan 1, 2003 | 09:25 PM
integls95's Avatar
Default Re: Hydro clutch problems, please help! (Nameless)
thanks guys, found a nice kink right on the line behind the manifold. It was pinched nicely but I do need to get a new line so once I install I'll tell ya how it goes.
kizzkizz10
Dec 9, 2011 10:18 AM
1badcrx
Nov 28, 2011 08:49 AM
iheartmy94eg
Jul 11, 2008 03:18 PM
matto2413
Sep 11, 2005 09:01 PM
B18PoweredCivic
Sep 24, 2003 10:58 AM
