Torque sequence for B18C1 valve cover?
Old Jan 2, 2003 | 08:39 AM
ebelp's Avatar
Default Torque sequence for B18C1 valve cover?
I've done some searching...no luck. What is the order? Thanks.
Old Jan 2, 2003 | 08:40 AM
Spade's Avatar
Default Re: Torque sequence for B18C1 valve cover? (ebelp)
Middle, top left, top right, bottom left, bottom right.
**** DOHC....um....brb.
Old Jan 2, 2003 | 08:41 AM
RaceTilIDie's Avatar
For valve cover? or head? For valve cover, the sequence isn't significant, just be sure not to overtighten or the studs WILL break. I think it's like 7 lbs/ft.
[Modified by RaceTilIDie, 5:46 PM 1/2/2003]
Old Jan 2, 2003 | 08:42 AM
ebelp's Avatar
Default Re: Torque sequence for B18C1 valve cover? (Spade)
hehe...thanks. Damn this forum moves fast...
Old Jan 2, 2003 | 08:56 AM
IN VTEC's Avatar
7.2lb*ft
3 1
4 2
Do this on teh inner four and then the outer four. That's teh pattern.
Old Jan 2, 2003 | 09:31 AM
ebelp's Avatar
Default Re: Torque sequence for B18C1 valve cover? (IN VTEC)
One more question...is it necessary to replace the rubber grommets that each bolt sits on?
Old Jan 2, 2003 | 09:39 AM
Spade's Avatar
Not unless they are rotted.
Old Jan 3, 2003 | 03:31 AM
ebelp's Avatar
7.2lb*ft
3 1
4 2
Can anyone else confirm this?
Old Jan 3, 2003 | 06:25 AM
RAWB's Avatar
7.2lb*ft
3 1
4 2
The Helms manual doesn't show a specific sequence. The above is the way I do mine, never had a problem. 7.2 ft/lbs
Old Jan 3, 2003 | 11:04 AM
bojangs's Avatar
New User
Default Re: Torque sequence for B18C1 valve cover? (RAWB)
i've always tightened mine in a criss cross pattern.. either way you should be fine..
Dekorum
Dec 29, 2011 09:36 PM
acmoc
Jul 3, 2008 05:39 PM
JDM_lover03
10
Oct 19, 2004 07:06 PM
honda lover
Jul 12, 2004 08:37 PM
