? on piston size & cylinderbore
Old Jan 1, 2003 | 12:20 PM
B pwr's Avatar
Default ? on piston size & cylinderbore
1.when they say piston/ or bore, 20 or 50 over and so on, i know it means bigger, but what does that equate to in millimeters?
for example, dont qoute me, not to sure, but i thought 20 over = .5mm
i ask because:
i purchased a gsrb18c block - it was already bored and honed (50 over) when i got it, so ill be needing some pistons for it, just not to sure & i need to determine the piston size to get.
any assistance/post are welcome
thanx
Old Jan 1, 2003 | 01:10 PM
Kataku2K3's Avatar
Default Re: ? on piston size & cylinderbore (crxpwr)
My guess if they say it is bored 50 over they are talking about hundredths of a millimeters, as in .50mm... All you gotta do is use a caliper on it to measure the bore.. If i'm right then just slap some 81.50mm slugs in there... Peace
[Modified by Kataku2K3, 2:11 PM 1/1/2003]
Old Jan 1, 2003 | 03:13 PM
IN VTEC's Avatar
10 over = .0100" overbore = .25mm overbore
If it's in empirical, then 50 over = 2.25mm overbore.
Total bore size = 82.25mm
Edit: Ooops.....81mm + 2.25mm = 83.25mm, not 82.25mm.
[Modified by IN VTEC, 7:21 PM 1/2/2003]
HPfreak
12
Nov 28, 2011 05:19 PM
Quetzolcotl
Mar 20, 2003 08:50 AM
GreenR
Jan 29, 2003 03:39 AM
