tech question
Old Jan 1, 2003 | 06:54 PM
jumpmann23's Avatar
From: Your really lame if you dock my points, WA, 98033
Default tech question
do i need a 99-00 civic si wiring harness for my b16a swap in a 96 hatch? this is what i was told can someone clarify this for me. my car is 1996 civic dx hatchback. thanks any information would be helpful
Old Jan 1, 2003 | 07:46 PM
HybriDNA's Avatar
Default Re: tech question (ek9folife)
I believe you just lengthen a couple wires on your stock civic harness and you just add the Vtec soleniod, Oil pressure, knock sensor wires separetly to the correct ECU pin out's. I may be wrong tho.
Old Jan 1, 2003 | 08:25 PM
Hybrid Garage's Avatar
I assume you have a 2nd generation B16A or newer. If so, reuse your stock engine harness. If you have an OBD-1 P30 ECU, then get a harness adapter from OBD-2 to OBD-1. Reuse your stock engine harness by extending the connectors wherever necessary. Wiring of the distributor takes some creative electronics knowledge.
pnapolitano29
Nov 26, 2014 07:30 AM
civic_hatch99
Sep 9, 2013 09:40 AM
delorean
Apr 5, 2011 01:26 PM
oresama
Oct 15, 2009 09:21 AM
hmtcrxsir
40
Sep 21, 2007 06:21 PM
