ls vtec oil leaks?
Old Jan 3, 2003 | 01:41 PM
wm5holla's Avatar
Default ls vtec oil leaks?
i really want to go ls vtec , but the guy, said it wont last, oil leaks and ****... what i can do to stop this from happening!! heres what he said ...
ChickNapper: b20 is a poor mans type r motor
WM5HOLLA: noo
ChickNapper: and in the long run....its more expencive to take care of
WM5HOLLA: long long?
WM5HOLLA: long run?
WM5HOLLA: what u mean
ChickNapper: not b20...
ChickNapper: i meant lsvtec
WM5HOLLA: y?
ChickNapper: in the long run....in a coupple of months years...
ChickNapper: the motor falls apart
ChickNapper: oil leaks
WM5HOLLA: the same will happen to a crv vtec
ChickNapper: yeah most likely
WM5HOLLA: oil will leak from where??
ChickNapper: wasnt built to last
ChickNapper: where else would oil leak from???
WM5HOLLA: why wont a b20 leak?
ChickNapper: b20..?
ChickNapper: plain b20?
ChickNapper: or crvtec....
WM5HOLLA: why wont a b20 vtec leak?
ChickNapper: who said it wont leak
WM5HOLLA: u said
ChickNapper: im just saying it will take a lsvtec...
WM5HOLLA: why wont a b20 and ls vtec last?
WM5HOLLA: what happens
ChickNapper: u gotta do some research man
Old Jan 5, 2003 | 12:48 AM
PornstaR16L's Avatar
Default Re: ls vtec oil leaks? (wm5holla)
BS if everything is tight just like every other motor in the world it wont leak
he was probably to poor to aford all the AN fittings and used some cheap
brass or something............... its cool it wont leak but build it good cuz if you dont
BANG it will blow like that so good luck oh and what "guy"
is he some kind of god cuz I dont know him
[Modified by PornstaR16L, 1:49 AM 1/5/2003]
Old Jan 5, 2003 | 09:23 AM
JDM92CX's Avatar
Default Re: ls vtec oil leaks? (PornstaR16L)
How could you communicate with that conversion?
Old Jan 5, 2003 | 10:23 AM
b18bvtec4drteg's Avatar
BS. Talk to someone that owns one. It is critical whoever that builds it knows what they are doing. I had my lsvtec for a little over 3 yrs. Still running strong. The only thing it leaked was my stock cam seal. But that still happens with stock or modded gsr's.
Old Jan 5, 2003 | 11:42 AM
sslude's Avatar
Default Re: ls vtec oil leaks? (b18bvtec4drteg)
i heard that the oil "burns" somehow faster than a regulrar car.
Old Jan 5, 2003 | 11:48 AM
Kataku2K3's Avatar
jesus christ... Chicknapper is a ****** retard.. who is that guy??? Oh well just as b18bvtec4drteg said, a properly built LSVTEC shouldn't leak at all... It actually should hold up just as well as any other DOHC VTEC motor but there are just several weak points that aren't even that bad... #1 the stock rods, and crank aren't as stong as their VTEC counterparts...., the blocks themselves aren't as strong or meant to be reved sky high... Again they still hold up fine... Build it right and you'll be set... The only places I could think about an LSVTEC over say a B16A/B, B18C/1/5 is through the oil feed journal... As long as you plug it right it should be cool... Any other place is just gonna leak as a normal motor that isn't built right... ie the cam seals, main seal, oil pump seal, headgasket, cam cap, distributor o-rings, etc... Peace
Old Jan 5, 2003 | 11:51 AM
Kataku2K3's Avatar
Default Re: ls vtec oil leaks? (sslude)
Not anymore than a normal car... Again as long as it's built right and you break it in correctly you should be fine... It's just like any other built motor... The downside to the newer B18B and B20B/Z motors is the lack of the PCV system... It's a good idea to put a catch can on them because of their tendancy to pull oil through the breather... Laterz
Old Jan 5, 2003 | 04:10 PM
Phaze2 Mike's Avatar
Default Re: ls vtec oil leaks? (Kataku2K3)
give chicknapper a break, hes just getting into the scene, i talked to him a few times, although here, i dunno wtf hes saying.
JDMeman
Apr 18, 2008 07:46 AM
urtz
Dec 9, 2006 02:50 PM
urtz
Dec 6, 2006 02:11 PM
championshipintegra
Jun 15, 2004 11:17 PM
sleepyhamsterlx
Aug 2, 2003 10:48 AM
