JDM shift boots
Old Jan 4, 2003 | 10:50 AM
CivicUnrest's Avatar
Default JDM shift boots
I was looking on inlinefour.com (a fine place for all things honda) and I am considering getting a shiftboot. I have a 2000 Civic Si and I am debating between the Civic Type_R and Integra Type-R shift boot. Both are black with red stiching, I was just wondering if any of you guys knew the difference between either one. Thanks for the help, I appreciate it!
Old Jan 4, 2003 | 02:27 PM
Kataku2K3's Avatar
Default Re: JDM shift boots (CivicUnrest)
They should be the same... Even if the bracket is different on the ITR just use your stock 2000 Si one... My friend just got a CTR one the other day for his EK and it bolted straight in... Like i said tho, either will work... Then if you don't already have one.. just slap an ITR/CTR shift **** on there.. It looks pretty clean after that, but you need an Integra bar... I'm pretty sure even tho you have B series linkage that the 99-2000 Si linkage has the thinner style bar as apose to that of an Integra... You can modify an integra bar if you want.. That's what I would do... Peace
schneedrache
Jan 22, 2014 09:17 PM
CivicUnrest
Jan 4, 2003 03:51 PM
CivicUnrest
Jan 4, 2003 11:34 AM
done
Jan 30, 2002 07:02 PM
ImprtTunr
Aug 3, 2001 07:06 PM
