clunking in the front suspension
Old Aug 26, 2003 | 04:43 PM
brbHPR's Avatar
Default clunking in the front suspension
i have an 89 civic and whenever i am braking or hit a hard bump, the front drivers suspension makes a clunking/popping noise. there is alot of play in the steering, and it's also very stiff turning-wise. the wheel also seems to have a bit more camber on that side.
any ideas on what it could be?
Old Aug 26, 2003 | 04:50 PM
VTECorona's Avatar
Default Re: clunking in the front suspension (brbHPR)
Who did the install? Was everything torqued to factory spec?
Old Aug 26, 2003 | 06:10 PM
Jdm93civic's Avatar
Do you have stock shocks? is it lowered? Tires Rims?
Old Aug 26, 2003 | 06:28 PM
Stripped Honda's Avatar
99-0104
Default Re: (Jdm93civic)
to me it sounds like the ball joints are worn out or the tie rod ends ... but i would bet on it being the ball joints
Old Aug 26, 2003 | 07:03 PM
Mike P.'s Avatar
25 Year Member
Probably time for new BJs as the others said. It would also not hurt to check the bushings in the upper shock mounts. If they are originals, it wouldn't hurt to replace them as they are now 14 years old.
Old Aug 26, 2003 | 08:44 PM
brbHPR's Avatar
Default Re: clunking in the front suspension (Mike P.)
oh, when i pushed down on the car, it makes a clunking sound.
if that helps any
Old Aug 26, 2003 | 09:41 PM
XrcR6's Avatar
Another possibility (after you check the ball joints and tie rods)... Check the two bolts that hold each of the radius rods to the front LCA. Sometimes they start to back out and the gap that forms allows some movement and knocking noise when they hit the LCA or bolt heads.
From what you described so far, there's probably more than one thing loose or worn. You should really go over the whole front end to be safe.
harleyhumper444
May 30, 2011 11:26 PM
lmike6453
Mar 7, 2008 10:57 PM
evad
Dec 6, 2004 09:28 AM
black_cap
Oct 9, 2004 03:18 AM
vtecn8ive
11
Jun 4, 2004 07:17 PM
