leakdown test results, your opinion please
Old Aug 27, 2003 | 09:21 AM
torr's Avatar
Default leakdown test results, your opinion please
3 cylinders are around 30% and the other one is at 7%.
the reason i did a leakdown is because i suspected that my car was burning oil. last week i went on a trip and drove it approx. 700 miles. by the end of the trip my oil light popped up. i checked my distick and there was no oil left. it took 4 quarts to fill it.
my motor is- ls/vtec with 3000 mile on it. what do you guys think about those leakdown numbers. thanks
Old Aug 27, 2003 | 10:16 AM
eg6ajk's Avatar
Default Re: leakdown test results, your opinion please (torr)
sounds like you have problem on your hand. numbers are way too high.
Old Aug 27, 2003 | 02:00 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torr &raquo;</TD></TR><TR><TD CLASS="quote">last week i went on a trip and drove it approx. 700 miles. by the end of the trip my oil light popped up. i checked my distick and there was no oil left. it took 4 quarts to fill it.
Driving around with no oil will destroy an engine very fast. I'm surprised your leakdown numbers are as good as they are. Sounds like time for a new motor.
Old Aug 27, 2003 | 04:21 PM
non-VTEC's Avatar
damn........30% leakdown...........sounds like you have holes in your pistons
well maybe not holes but you definably have a piston ring problem.......either there worn right out or never seated properly.....
tear it apart and start over........thats your only solution.......
Old Aug 27, 2003 | 04:54 PM
Fkned2003's Avatar
Your rings are shot .Time for a rebuild
Old Aug 27, 2003 | 05:09 PM
WundedSaint's Avatar
Are you sure you did the test correctly? Did you listen or feel for where the air is going out? There's only three places that the air can go out, oil dipstick tube (rings), intake manifold (pull a vaccum line after the throttle body) , and muffler (burnt valve). Is your exhaust blowing smoke? Really worn valve guides will also make you burn oil.
Old Aug 27, 2003 | 06:08 PM
torr's Avatar
Default Re: leakdown test results, your opinion please (WundedSaint)
thanks guys, yeah i did the test correctly. i suspected the rings to be at fault. hopefully i didn't damage anything else.
Old Aug 27, 2003 | 08:25 PM
TREVER's Avatar
If you did the test correctly where did the air come out of? You shouldn't be suspecting rings. A leak down test will tell you for sure, If you know how to do it correctly. I look for 5-10% max btw.
Old Aug 28, 2003 | 04:35 AM
torr's Avatar
Default Re: leakdown test results, your opinion please (TREVER)
yes, i did it right. i have 2 holes drilled into my vavle cover connected to a catch can,( like the one that endyn has on their 2.0L build up). air was coming out of the catch can.
Old Aug 28, 2003 | 05:58 AM
T4eg's Avatar
thats really high. Its time fore rebuild now
Old Aug 28, 2003 | 07:46 AM
1bad-eg's Avatar
Have you also looked for any visual leaks?
Old Aug 28, 2003 | 09:21 AM
torr's Avatar
Default Re: leakdown test results, your opinion please (1bad-eg)
no visual leaks found. after a day of driving the garage floor is dry too.
Old Aug 28, 2003 | 01:56 PM
TREVER's Avatar
then it's in the crank case sounds like rings
Old Aug 28, 2003 | 10:31 PM
jdm_integ's Avatar
just transplant a d16 and you'll be good. hahahaha
j/k time for another massive rebuild.......with turbo!!!
Old Aug 29, 2003 | 04:26 AM
torr's Avatar
Default Re: leakdown test results, your opinion please (jdm_integ)
shut up scott, i'll kill you
Nicks95GSR
Sep 28, 2007 10:54 AM
RiCE On IcE 2
Apr 11, 2006 12:00 PM
bigslimdog
42
Mar 27, 2004 03:02 PM
LuckyNuts
Sep 21, 2003 12:49 PM
silvlude
Jul 31, 2003 05:12 PM
