Oil overfill?
Old Aug 27, 2003 | 10:14 AM
CHRIS 1.8's Avatar
Default Oil overfill?
What happens if you use more oil than you are suppose to? On the dipstick, the maximum oil line is past the top. I used 5 quarts of Mobil1 FUll Synthetic 10W-30. Are there any effects?
Old Aug 27, 2003 | 10:16 AM
CRX Si's Avatar
Default Re: Oil overfill? (CHRIS 1.8)
high oil pressure is rough on your seals... Pretty much if you put too much oil in, the extra oil will find a way out... You may see some oil leaking out hear and there...
Old Aug 27, 2003 | 10:18 AM
eg6ajk's Avatar
loss of power....
Old Aug 27, 2003 | 10:54 AM
CHRIS 1.8's Avatar
Default Re: Oil overfill? (eg6ajk)
I'll go ahead and drain some out.
Old Aug 28, 2003 | 12:40 AM
GOLDBERG's Avatar
drain some
Old Aug 28, 2003 | 06:01 AM
T4eg's Avatar
Default Re: Oil overfill? (GOLDBERG)
Too much oil will cause a motor to spin a bearing. When the oil is overfilled air bubbles get formed. and the oil gets thicker and thicker.
FitsMe
Honda Fit
Apr 16, 2012 05:05 AM
EG_Civic_Si
Feb 6, 2011 04:05 AM
gooknom
Mar 17, 2004 10:20 AM
