camber kit questions
Old Sep 30, 2003 | 05:13 PM
SD_EM1's Avatar
Default camber kit questions
alright so i went to get an alignment for my car, and i found out my camber is way off. the rear is about 2 degrees negative, and the front 1.5 degrees negative. so the mechanic recommended to me to get a camber kit if i wanted to keep my car at its current height. so now my question is... which one?
for the past few hours, i have found but only good things for the SRR rear camber kit. so that is most likely what i will get for rears. as for the front, this is my real debate. i have been reading that skunk2's camber kits have had tearing balljoint problems on their later models. so i don't know if i should go for the skunk2 or not. the other choice i was thinking was to get the SPC front camber kit. which one do you guys suggest?
as for the SPC front camber kit, which one do you guys have (model number specific)? is there only 1 type? because i have only found a ball joint only version. here is the link ...
http://www.tornactive.com/pd_s...r.cfm ball joint
my other question is, can i just get the ball joint and attach it to my stock A-arm?
would you guys get the SRR rear camber kit and SPC front camber kit? or would you just go straight with SPC all around? tornactive sells both front and rears from SPC
http://www.tornactive.com/cat_honda_cviic.cfm
please help. i am in urgent need of a camber kit. thanks in advance
edit: the link to the arms on spc's website was for the rear arms only. sorry about that. i guess there isn't a modified a-arm from SPC?
Modified by One Slow Civic at 6:30 PM 9/30/2003
Modified by One Slow Civic at 6:34 PM 9/30/2003
Modified by One Slow Civic at 7:25 PM 9/30/2003
Modified by One Slow Civic at 7:26 PM 9/30/2003
Old Sep 30, 2003 | 06:27 PM
SD_EM1's Avatar
Default Re: camber kit questions (One Slow Civic)
anyone?
any help is appreciated
Old Sep 30, 2003 | 09:17 PM
cavakilla's Avatar
if you are asking about your 00 si, this is my opinion... buy the skunk 2's for the front and get some longer bolts and washers for the rear... get about 10mm longer bolts and 12 or 16 washers all the same thickness this should be plenty to take care of two degree's... most kits come this way anyway and you don't really need an adjustable arm if you are not changing it very often... as far as having problems with skunk 2 uca's i have customers autocrossing for two summers and haven't seen any problems yet... good luck tom
FLACO EM1
Nov 27, 2008 01:39 PM
JTaudio0212
Honda Civic (2006 - 2015)
18
Oct 25, 2007 04:58 PM
fafsa
Apr 6, 2005 03:40 PM
SD_EM1
Sep 30, 2003 08:58 PM
FourthGenHatch
10
Sep 1, 2002 10:23 AM
