Updated Tranny Noises
Old Sep 26, 2003 | 04:07 PM
Tchleung's Avatar
Default Updated Tranny Noises
Here are my problems...
1: Grinding/garggling noise when foot is off the cluithc. both at idle and when driving. cluthc in it goes away
2: Makes a sand paper type of scracthing noise in the 3-4 grand range weather accelerating or decellerating thru taht range
3: Makes taht same sand paper kinda noise in between shifts. in that same range. not as noticeable lwoer or higher
4: does it in msot gears. not surea bout 5th tho.
5: Makes a kinda knocking sound when i go over a bump. a quick knock where I can feel it in the floor board
6: when I was testing the at idle, clutch ni and out thing with the throw out bearing. as soon as I cluthc in. the noise goes away but right after that thre isa faint knock, knock, knock sound. 3 knocks. they are quite and the volume of each knock decrease till it stops, almsot like the bearing just kiand spins then drps, rotates a bit mroe, tehn drops liek no bearigns at all
that's about sums it up. it's comngi from tranny for sure by the way/area the sound is comnig from and I checked all the moutns thinknig maybe some were busted and itw as hanging and not aligning properly.
Old Sep 26, 2003 | 09:55 PM
Mr.DC2TurBo's Avatar
Default Re: Updated Tranny Noises (Tchleung)
sorry to tell u dude, its an input shaft bearing. Don't buy anything used unless u know wat car it came from or from a person u trust. used=old worn out parts
Modified by Mr.DC2TurBo at 8:29 PM 10/7/2003
Old Sep 27, 2003 | 12:49 AM
Tchleung's Avatar
Default Re: Updated Tranny Noises (Mr.DC2TurBo)
yeah. tonight we concluded that it's the input shaft bearing. F&CK! soooooooooooooooo I am jsut gonna ge it rebuild alonbng with the other bearings in the tranny case.. gonna cost me alot.. cheaper then a tranny tho. yeah this tranny came with my motor swap so... :S
CRX-CHACE
Sep 15, 2013 07:45 PM
acracer2008
Aug 2, 2010 05:35 AM
MrExclusive
16
Mar 9, 2010 08:49 AM
Aquafina
Jun 3, 2008 05:58 PM
CimorelliCRX
14
Jan 25, 2003 07:54 PM
