LS/VTEC (CRX)???
Old Sep 29, 2003 | 08:02 AM
gogou99's Avatar
Default LS/VTEC (CRX)???
i swap my b16 motor and i had built an ls/vtec which was put in, the problem im having is that it run like **** (its bogs alittle, almost like its missing) with obd0 ecu, i have 2 obd0, my friend let me use his stock 88civicsi ecu just to see if it does anything and it runs much better with it which i cant understand, i still got to break in the motor before i go to get it tuned, has anyone had this problem before?
1990crx 1.8,- pnp, w/ JE slugs, Crower 63402 cams/springs/pf retainers, aem gears, hondata stage2(not installed yet) oem lighten flywheel, clutchmasters stage3, rsr header, 2.5 custom exh.
Modified by gogou99 at 6:30 PM 9/29/2003
Modified by gogou99 at 6:31 PM 9/29/2003
Modified by gogou99 at 6:32 PM 9/29/2003
Modified by gogou99 at 6:52 PM 9/29/2003
Old Sep 29, 2003 | 08:32 AM
martini's Avatar
Default Re: LS/VTEC (CRX)??? (gogou99)
what ECUs were you running before?
Old Sep 29, 2003 | 09:15 AM
gogou99's Avatar
Default Re: LS/VTEC (martini)
with my b16crx, (obd0 pr3)
kron0ne
25
Dec 20, 2003 08:05 PM
soprano2005
Oct 6, 2003 05:40 PM
ggangtong81
Sep 13, 2003 08:05 PM
