OBD2 Location of second O2 sensor
Old Sep 30, 2003 | 12:30 PM
Leb_CRX's Avatar
Default OBD2 Location of second O2 sensor
on a OBD2 car does the secondary O2 have to be located BEHIND the cat or can it be in front in front of the cat??
the reason I ask this is because I saw some headers for sale on ebay, and the secondary O2 was plugged into the DP, and the first one was plugged directly into the header, not leaving a place for the CAT to be (well after DP)...now to my knowledge this would throw a code since the ECU is suppose to be reading the reading after the CAT
Can anyone confirm in this in fact will throw a code or not...
Thanks
Old Sep 30, 2003 | 12:31 PM
Audi RS4's Avatar
Lover
Default Re: OBD2 Location of second O2 sensor (Leb_CRX)
it is usually behind the cat, i think that's where it belongs!!
Old Sep 30, 2003 | 12:44 PM
wickedEFguy's Avatar
yeah for OBDII it'll be behind the cat
Old Sep 30, 2003 | 03:53 PM
Smith Wise's Avatar
Default Re: OBD2 Location of second O2 sensor (Ninja_Jc7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninja_Jc7 &raquo;</TD></TR><TR><TD CLASS="quote">yeah for OBDII it'll be behind the cat </TD></TR></TABLE>
put it in front, and you shouldn't pass emissions
edit: you have emissions in Canada??
Old Sep 30, 2003 | 04:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leb_CRX &raquo;</TD></TR><TR><TD CLASS="quote">on a OBD2 car does the secondary O2 have to be located BEHIND the cat or can it be in front in front of the cat??
It should be behind the cat. The secondary o2 sensors sole purpose is to help the ECU tell if the cat is working or not.
Old Sep 30, 2003 | 06:17 PM
Leb_CRX's Avatar
Default Re: OBD2 Location of second O2 sensor (Jswpstdoff)
depends on where you live, in ottawa, canada, which is where i'm at, we have it...
I am all for emissions, I currently run a cat and would not run without one...my kids will be breathing the air one day, I was just wondering for personal knowledge
"Hites"
Feb 11, 2005 05:24 PM
2lobes1engine
11
May 11, 2004 03:14 PM
piotrush
Feb 9, 2004 09:51 PM
SIK IN DA HED
Dec 3, 2003 07:32 PM
JinMTVT
Aug 11, 2001 08:01 PM
