Few ?'S
Old Sep 26, 2003 | 07:58 PM
South sol's Avatar
Default Few ?'S
2000 Si with Intake/Header/Cat/Exhaust.
Put on dyno and it was kinda leveling out around 7/7.5k rpms we are going to see what is up with the air/ fuel with a scan tool just need to locate the port for obdII tuning. same for clearing codes I believe. Also what is the Stock compression in the Si? It is seeming to be "pig fat" on the top-end just doing some tuning before we take it any further, untill I get a response I will be doing preventive maintenance plugs, wires, etc.
Thanks
Old Sep 26, 2003 | 08:40 PM
SICKSOLSI's Avatar
Default Re: Few ?'S (South sol)
stock cr should be from the factory about 10.4:1
Old Sep 27, 2003 | 07:01 PM
South sol's Avatar
in PSI not ratio, thanks though
Old Sep 27, 2003 | 07:04 PM
mmuller's Avatar
Mad Scientist
Default Re: (South sol)
actually comp. on usdm is 10.2 and about 215/225 psi's
BoostedJeff
Honda Civic (2006 - 2015)
35
Mar 29, 2010 06:33 AM
ludecz
50
Oct 9, 2009 12:04 PM
Lifter2012
Mar 11, 2005 09:42 PM
BluSiBoy
27
Sep 29, 2004 11:27 PM
miataguy
34
Aug 5, 2003 06:30 AM
