B series question
Old Sep 30, 2003 | 09:46 PM
Thundersquid's Avatar
Default B series question
is there a way to separate the head from the block with out removing too much stuff?
Old Sep 30, 2003 | 10:22 PM
Padawan's Avatar
Darth ModerVader
Default Re: B series question (Thundersquid)
It depends on your definition of "too much stuff". While pulling a head isn't terribly difficult, it's not a 15 minute job.
Old Oct 1, 2003 | 04:24 AM
Audi RS4's Avatar
Lover
what's your point? explain what you don't want to remove. to remove the head you will need to remove all the vaccum lines, valve cover, timing belt, power steering pump bracket, intake manifold and acouple of other little things.
Old Oct 1, 2003 | 09:26 AM
Padawan's Avatar
Darth ModerVader
Default Re: B series question (AK1200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">intake manifold and acouple of other little things.</TD></TR></TABLE>
Actually, unless you need it removed for some reason, I feel leaving the IM on is easier.
Old Oct 1, 2003 | 11:27 AM
Audi RS4's Avatar
Lover
Default Re: B series question (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Actually, unless you need it removed for some reason, I feel leaving the IM on is easier. </TD></TR></TABLE>
i would to depending on what i was going to be doing with the head. he never said what he would be doing..
Old Oct 1, 2003 | 12:21 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">i would to depending on what i was going to be doing with the head. he never said what he would be doing.. </TD></TR></TABLE>
True, but he did say that he didn't want to remove "too much stuff".
Old Oct 1, 2003 | 12:29 PM
poison's Avatar
True, but he did say that he didn't want to remove "too much stuff". </TD></TR></TABLE>
You have to drain coolant and oil as well.
Old Oct 1, 2003 | 01:42 PM
Lsos's Avatar
Default Re: B series question (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">
You have to drain coolant and oil as well. </TD></TR></TABLE>
You don't have to drain the oil. It goes down to the oil pan. You only have to drain a little coolant.
Old Oct 1, 2003 | 01:50 PM
Audi RS4's Avatar
Lover
yes that is correct, i'm still wondering what he wants to do
Old Oct 1, 2003 | 03:06 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">yes that is correct, i'm still wondering what he wants to do </TD></TR></TABLE>
Now that you mention it, I am too.
Old Oct 4, 2003 | 06:46 AM
I'm replacing all the gaket on the head gasket
Old Oct 5, 2003 | 07:43 AM
nominous's Avatar
You dont have to remove the timing belt, you can (ghetto alert) just undo the bolts holding the cams in and tilt them off to one side.
Old Oct 5, 2003 | 07:51 AM
spaceman's Avatar
i would drain some coolant out(save it to re-use if its still good)then unbolt the intake manifold but just push it out of the way(that way you dont have to remove the fuel lines)then ya i dont know about the removing the cam way,but you will probably have to remove the timing belt..then disconnect the bottom part of the headers(just under the 2 o2 sensors if you have the factory headers)..let me know if you peeps think this technique will work ok?
Old Oct 5, 2003 | 08:28 AM
Audi RS4's Avatar
Lover
Default Re: (nominous)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nominous &raquo;</TD></TR><TR><TD CLASS="quote">You dont have to remove the timing belt, you can (ghetto alert) just undo the bolts holding the cams in and tilt them off to one side.</TD></TR></TABLE>
feel free to smack yourself at anytime during this thread
Old Oct 5, 2003 | 08:39 AM
2camsaam's Avatar
HOW?
Old Oct 5, 2003 | 09:02 AM
spaceman's Avatar
Default Re: (AK1200)
lol...thats what i was thinking..
Old Oct 5, 2003 | 09:55 AM
nominous's Avatar
try it
Its not removing the timing belt since its still wrapped around the crank at the bottom of the block.
I suppose if you wanted to be really daft, you could just undo the bolts holding the cam gears on and then ......
Old Oct 5, 2003 | 09:59 AM
spaceman's Avatar
i guess thats possible..are you really in england?
Old Oct 5, 2003 | 11:14 AM
Audi RS4's Avatar
Lover
excuse my ignorance, but what does DAFT mean?
Old Oct 5, 2003 | 02:17 PM
nominous's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK1200 &raquo;</TD></TR><TR><TD CLASS="quote">what does DAFT mean?</TD></TR></TABLE>
Stupid thing to do.
As in: putting his nuts in the blender was a daft thing to do.
Yeah, Im really in England, with a nice Celestial Blue CRX VTEC with a b20VTEC swap
Old Oct 5, 2003 | 02:23 PM
spaceman's Avatar
coolness..how is england?
Old Oct 5, 2003 | 02:33 PM
nominous's Avatar
Cold, wet, expensive, everything you'd expect
Old Oct 5, 2003 | 02:35 PM
Audi RS4's Avatar
Lover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nominous &raquo;</TD></TR><TR><TD CLASS="quote">Cold, wet, expensive, everything you'd expect </TD></TR></TABLE>
i have been to Portsmouth and London....very good time
Old Oct 7, 2003 | 06:24 AM
Lsos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nominous &raquo;</TD></TR><TR><TD CLASS="quote">try it
I suppose if you wanted to be really daft, you could just undo the bolts holding the cam gears on and then ...... </TD></TR></TABLE>
That's what I did...just taped the cam gears to the timing belt to hold them in place and unbolted them from the cams. It just seemed logical when I was doing it...
kingofnothing
Oct 20, 2008 04:39 PM
blkteggy
Sep 19, 2007 11:07 PM
bboy_mikey
Sep 4, 2006 04:22 PM
The Weather Man
Mar 27, 2006 02:50 AM
veilsides2000
Jul 4, 2005 03:08 PM
