overheating problem solved
Old Sep 30, 2003 | 12:23 AM
paz's Avatar
paz
Default overheating problem solved
hopefully this helps someone down the road.
I had an overheating problem that had very similar symptoms to a cooling system that hadnt been bled properly.
I searched this board and a few others for ideas one thing that never came up was oil. I replaced thermos raidators bled and re-bled the system, to no avail.
Turns out my oil pump was goin out, it maintained enough pressure to keep the oil light off. but didnt pump enough oil to properly lubricate thus causing increased heat. Anyway ne woil pump problem solved.
thanks for the b/w
Old Oct 3, 2003 | 05:18 AM
chad's Avatar
Moderator
Default Re: overheating problem solved (paz)
good INFO!!!!!!!!!!!
Old Oct 3, 2003 | 07:53 AM
sackdz's Avatar
Default Re: overheating problem solved (chad)
one reason i wish hondas came with factory oil pressure gauges.
bnmm
21
Dec 22, 2013 07:15 AM
TypeRod
Sep 7, 2011 08:48 PM
eg-gsr423
Oct 27, 2009 08:57 AM
jg870
Jan 4, 2008 07:08 PM
