still smokeing !!or will it go away
Old Sep 28, 2003 | 01:34 PM
DJone850's Avatar
Default still smokeing !!or will it go away
i just got done building my boy car agian and we put new rings bearings ect. ect . and we stared it and it runs like a champ ... but the thing that worries me is that its still blowin grey smoke , and i though it would stop after 1 day .. but now its day 4 and still smoking .... is it beacuse the rings hasent seat yet ??? and its still in the 1000 breakin mile..
Old Sep 28, 2003 | 01:38 PM
HONDADNA's Avatar
Default Re: still smokeing !!or will it go away (StreetStars)
did you check the piston to wall clearance? did you have ring ring gaps? and spaced the ring 180 from each other?
Also if the rings are installed backward this will cause oil to pass the ring and into the chambustion chambler.
Old Sep 28, 2003 | 02:06 PM
DJone850's Avatar
Default Re: still smokeing !!or will it go away (HONDADNA)
yes yes did that 180 them also ....im stuck ...i odnno what is causeing it to smoke ...im thinkin is beacuse were still in break in it in ...
Old Sep 28, 2003 | 10:00 PM
hungrymonkey's Avatar
during the break in period everything is tight, you shouldnt have any blow by to cause it to smoke.
what type of rebuild did you do? re-ring, or complete?
did you check all of the clearances?
Old Sep 29, 2003 | 08:52 AM
HONDADNA's Avatar
I forgot to asked if you check valve guide wear and did you replaced the valve seals?
Old Oct 1, 2003 | 01:48 PM
DJone850's Avatar
replaced all the rings and seals , and on the head we did the valve seals .....do you think runing a test pipe will cuse smoke since ther is on cat. thier ???
ianp3k
Apr 24, 2008 12:05 PM
aftershk
Apr 12, 2007 10:05 AM
H9Omega
16
Dec 14, 2006 06:28 PM
Chuji
Aug 19, 2003 02:06 PM
