failed smog in cali
Old Sep 30, 2003 | 06:10 PM
GSRacer1's Avatar
Default failed smog in cali
first i went to smog the bitch i got these numbers
at 15 mph
hc 113 max allowed were 61
co 0.51 max " " 0.54
nox 2072 max allowed 467
at 25mph
hc 29 max 45
co 0.49 max 0.53
nox 966 max 754
second time --
OK, I changed the cat with a new carsound cat and put in some of that denaturized alcohol, put the timing back 2 degrees, got new plugs
and
you know what, I hate california's smog laws
I passed the nox part with flying colors but
hc and co2 levels went sky high
new numbers are
15mph test
GAS- MAX - MEASURED
HC - 61 - 170
CO - 0.54 - 2.44
NO - 467 - 43
25MPH TEST
HC - 45 134
CO - .53 1.85
NO - 754 32
PLEASE HELP
can i figure this out with out breaking bank
Old Sep 30, 2003 | 06:40 PM
GSRacer1's Avatar
Default Re: failed smog in cali (GSRacer1)
i need some answers people
Old Sep 30, 2003 | 07:25 PM
farside's Avatar
Since your below on the nox, advance the timing. Sparking earlier will get a better burn. How is your air filter looking? You can alos clean out your intake and such, that'll drop the emissions a bit. Also, you can run 89 octane. It'll also burn better. Just run the tank down to E and then fill it up with a little 89 or 87. After fill it back up with what ever you use.
Old Sep 30, 2003 | 08:44 PM
hi-Powered's Avatar
high CO due to a rich air/fuel mixture .
causes: high fuel pressure, leaking fuel injector, dirty air filter.
high CO can also cause high hc.
run 91 octane.
make sure you don't go the smog station when 100degF outside.
Old Sep 30, 2003 | 11:58 PM
WundedSaint's Avatar
Default Re: (numbnut)
He can't be running too rich because his NOx is over 2k.
The CO isn't very high it's still less than 1%
CO is function of HC combustion, so CO can't cause high HC.
so you like to call yourself numbnut eh?
Wherever you learned your information about engine combustion IS WRONG.
If you want to give advice, please make sure you know what you're talking about.
Otherwise, just read and ask questions like everyone else.
Old Oct 1, 2003 | 09:28 AM
10K2HVN's Avatar
Default Re: (WundedSaint)
im screwed..
https://honda-tech.com/zerothread?id=634800
Old Oct 1, 2003 | 10:47 AM
MaaseyRacer's Avatar
clean your throtle plate
replace your PCV valve
if you can get one of those apex air fuel controllers my buddy got one, and used it to pass smog.
change your distributor cap and rotor, if necessary
Old Oct 1, 2003 | 01:03 PM
GSRacer1's Avatar
Default Re: failed smog in cali (MaaseyRacer)
first of all i passed the nox the second time after changing the cat but failed the hc and co
and the sparkplugs and rotor and cap are new but the air filter is preety old maybe that could be the problem
Old Oct 1, 2003 | 01:06 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRacer1 &raquo;</TD></TR><TR><TD CLASS="quote">first of all i passed the nox the second time after changing the cat but failed the hc and co
what other mods does your engine have?
specifically, are you running some kind of header other than the stock exhaust manifold?
Old Oct 1, 2003 | 01:23 PM
HumanResource's Avatar
Get hotter Spark Plugs (2 steps like a 4E)
Lower Fuel Pressure
Make sure you go with a clean change of oil for engine AND tranny!
Should get you to 1.5 SOHC emission readings
avrfan
May 13, 2015 06:29 PM
slayersluck
Engine Management and Tuning
Mar 6, 2009 04:32 PM
thao4life
Mar 15, 2004 11:03 AM
GSRacer1
Oct 9, 2003 10:40 AM
SimbaDogg
Jul 2, 2003 09:17 AM
