compression results
Old Sep 30, 2003 | 06:53 PM
jeremy.'s Avatar
Default compression results
warmed the car up and shut if off...waited 10 min then took plugs out. gassed it and cranked it 4 or 5 times. setup is a b16 head on gsr block with jdm itr pistons. got 240, 210, 240, 235. i dunno what's up with #3. what could be the problem? worn piston ring?
Old Sep 30, 2003 | 07:21 PM
T4eg's Avatar
Default Re: compression results (ek_jeremy)
those are fairly good numbers. If the rings were bad they would be alot lower. IMO
Old Sep 30, 2003 | 10:00 PM
cavakilla's Avatar
do a leak down that way you can see where you losing pressure it could be just some carbon on the valves... good luck tom
projectTeG
23
Mar 31, 2010 08:18 PM
preludedriva
13
Sep 3, 2007 12:34 AM
Vpenh
Aug 6, 2006 10:30 AM
hondeducation
Jun 18, 2005 11:42 PM
jeremy.
11
Oct 2, 2003 04:45 AM
