bogging at vtec
Old Sep 29, 2003 | 02:53 PM
that_guy's Avatar
Default bogging at vtec
obdo b16a into a crx dx
zdyne 1 wire acu (though the all wires are still hooked up)
ok well the motor is in and it runs great, until i hit vtec. when i get into vtec range it starts to bog. any ideas as to what it may be? thanks
Old Sep 29, 2003 | 09:52 PM
that_guy's Avatar
Default Re: bogging at vtec (that_guy)
no ideas?
Old Sep 30, 2003 | 12:06 AM
92 civic VX B18c's Avatar
HT Black Ops
Is your vtec crossover set to the stock place? What are all the mod you've done, the more descriptive you can be the better
Old Sep 30, 2003 | 06:26 AM
that_guy's Avatar
Default Re: bogging at vtec (92 civic VX B18c)
vtec crossover is set stock (5200) on a zdyne one wire ecu. mods are skunk2 stage1 cams, skunk2 Im, hondata IM gasket, intake/header/high flow cat. Im pretty sure that all of that should be working as this all was taken out of my integra which i drove the day before the swap. another wierd thing is that if i disconnect the vtec solenoid it does fine not only before the crossover, but after as well. any help is appreciated, thanks
Old Sep 30, 2003 | 06:35 AM
quikyEG's Avatar
do you have upgraded injectors.....they might be dumping more fuel then you need if thats the situation
Old Sep 30, 2003 | 09:31 AM
that_guy's Avatar
Default Re: bogging at vtec (quikyEG)
nope, just stock ones
Old Sep 30, 2003 | 09:37 AM
HT Black Ops
Have you ajusted the timing on the cams? If not your bogging bacause of that, you may need to raise your vtec crossover to something like 5500rpms-6000rpms
I have skunk2 stage 2s and I have my vtec cross over set @ 5800rpms
Old Sep 30, 2003 | 12:22 PM
that_guy's Avatar
like i said the motor is being swapped from my old integra where it ran fine, and nothing has been changed so i dont think it is that
Old Sep 30, 2003 | 12:31 PM
HT Black Ops
How about your fuel pump? Is it the stock on on the CRX?
Old Sep 30, 2003 | 01:38 PM
that_guy's Avatar
yeah, actually were in the process of checking it right now
Old Sep 30, 2003 | 09:02 PM
that_guy's Avatar
i should also mention that it only bogs down from like 5200 to 6500 then its fine again
Old Sep 30, 2003 | 09:33 PM
cavakilla's Avatar
its your fuel mapping with your stage two cams... you must have changed something? did you have zdyne in teg? cams in teg? something changed... i see this alot with bigger cams. you will need a fuel tuning device, vafc, feilds, etc... and some dyno time to tune it out and you will probably end up engaging vtec at somthing like 6000 to 6500... good luck tom
Old Oct 1, 2003 | 05:57 AM
that_guy's Avatar
Default Re: bogging at vtec (cavakilla)
actually theyre only stage one cams, but the thing is that everything except the IM and IM gasket were exactly what was paired with my motor before and i was having no problems at all. its kind of frusterating
Old Oct 1, 2003 | 11:05 AM
MaaseyRacer's Avatar
I am going to agree with everyone else, get aw VAFC and raise you vtec engagment to like 5500 or 5800, and try that.
Old Oct 1, 2003 | 11:38 AM
that_guy's Avatar
Default Re: (MaaseyRacer)
is that really necessary with just stage 1 cams? I just am having trouble thinking that it is that as they cams were working great in the motor before i swapped it over into my crx
Old Oct 3, 2003 | 01:30 AM
all_stock's Avatar
Default Re: (that_guy)
is it cause there is less strain on the motor, cause of being in a lighter car??
siregcivic
67
Mar 13, 2013 03:45 AM
phatnucca
32
Apr 14, 2012 08:54 PM
jetoutant
11
Jan 2, 2008 07:50 PM
msbhvn_DC2
Feb 9, 2006 07:39 AM
mdj_ge
Jun 29, 2005 09:28 PM
