car running like sh*t
Old Sep 26, 2003 | 01:55 PM
MisterHYBRID's Avatar
Default car running like sh*t
Well, car was losing water, had the head redone and a new gasket put in. Now the car doesnt lose water but it RUNS LIKE SH*T. checked timing, put in new plugs and wires. Can ANYONE HELP!? it idles rough at 900-1000 and you cant push it past 4000. very, very sluggish.
Old Sep 26, 2003 | 02:26 PM
HONDADNA's Avatar
Default Re: car running like sh*t (MisterHYBRID)
Check your crank to cam timing - it sounds like that your timing is off.
You can actually verify this by doing a running compression test.
it should be about 60 - 90 psi about half the static compression. than snap the throttle compression should rise about 18% or 115 -120 psi. If idle compression is low it intake side problem and if you snap is low this will confirm that you have a intake problem.
or just simply check your crank to cam timing.
Old Sep 26, 2003 | 02:29 PM
spaceman's Avatar
thats what i was thinking too..who did the job?something obviously wasnt put back together correctly
Old Sep 26, 2003 | 03:00 PM
Default Re: car running like sh*t (spaceman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spaceman &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was thinking too..who did the job?</TD></TR></TABLE>
Honestly I usually dont do this type of work. However I really didnt want to pay for a headgasket job on a d15b8. A swap is coming soon and i dont want to waste money on the d15.
anyways I should adjust the crank to cam timing.
does that mean I would adjust it to tdc and just move the cam to the "up" position?
Im "kinda" new to this. Im trying and learning as I go. Thanks guys.
Old Sep 26, 2003 | 06:19 PM
The Internet Tough Guy's Avatar
also try resetting your ecu
Old Sep 28, 2003 | 01:04 PM
HONDADNA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MisterHYBRID &raquo;</TD></TR><TR><TD CLASS="quote">
Im "kinda" new to this. Im trying and learning as I go. Thanks guys.</TD></TR></TABLE>
Yes! you abjust to TDC. The up most at the up position and the crank white mark lined up to the timing belt cover.
Old Sep 30, 2003 | 10:24 AM
Default Re: car running like sh*t (HONDADNA)
ok, car is running ok now, but it still won't pick up speed. Could this be the cause of an exhaust leak...car is running without exhaust...and it is a 8 valve.
buffgsr
Jun 6, 2010 12:30 PM
DUHC
Oct 14, 2008 06:41 AM
Scrapin4DR
May 5, 2008 06:33 PM
Dave_Darling
12
Jul 12, 2007 08:40 PM
Samuels
May 26, 2007 08:34 PM
