3rd gear grind. Need help please..
Old Sep 27, 2003 | 12:05 AM
The Notorious Frosty's Avatar
Default 3rd gear grind. Need help please..
Ok, I took my car in to an Econo Lube today to have the transmission fluid changed because It was that time.. The car drove perfectly fine when I took it in. Now tonight everytime I try and shift into 3rd at a speed > 30mph it grinds. No other gears but third. I never drove the car hard tonight either, I am wondering if maybe they didn't put in enough fluid, or used the wrong grade or what?
In the manual honda says to only use their brand of MTF, but it also says you could even use 10w30 oil as a temporary fix. Eitherway it shouldn't grind should it? I'm wondering what I should do? So far I plan to go back to the econo lube to ask them what's up. And on me for not doing it myself or atleast taking it to the dealer. Btw the car is a 99 ex coupe with 61k miles.
Old Sep 27, 2003 | 02:16 AM
TimoneX's Avatar
New User
Default Re: 3rd gear grind. Need help please.. (Frosty18)
Yeah take it back and see what's what, but it's not uncommon for them to grind a bit w/ new fluid. I'm very particular about running Honda MTF in mine and never get grinds after fluid changes. If you're sure they put in oil, I'd have them put in Honda MTF this time and see if that clears it up.
Old Sep 27, 2003 | 07:42 AM
gitwidit's Avatar
Default Re: 3rd gear grind. Need help please.. (TimoneX)
If you take it back and they won't fix or try to and it still grinds use some gm synchromesh manual transmission fluid #12345349. It has friction modifiers in it that may help.
Old Sep 27, 2003 | 10:38 AM
Default Re: 3rd gear grind. Need help please.. (GITWIDIT)
Thanks for the input guys. and an Update: I went down there this morning and told the guy what's wrong etc. And so far he's being very nice about it.
He called the dealership and asked what to do, he put in honda's recommended "substitute" and the car still grinds. He told me Monday morning he would drive to the honda dealership himself and pick up some Honda MTF and change it out for me for free on Tuesday. But until then 3rd gear still grinds even with hondas recommended substitute.
Could that gear oil they used at first has permanently jacked my tranny?
Modified by Frosty18 at 12:19 AM 9/28/2003
Old Sep 27, 2003 | 03:06 PM
TTT
Old Sep 27, 2003 | 04:52 PM
Back to the top!
Old Sep 27, 2003 | 06:56 PM
mmuller's Avatar
Mad Scientist
as sayd above use gm synchromesh manual transmission fluid #12345349.
Old Sep 27, 2003 | 07:17 PM
Chiovnidca's Avatar
Default Re: 3rd gear grind. Need help please.. (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">as sayd above use gm synchromesh manual transmission fluid #12345349.</TD></TR></TABLE>
Is that better than Honda MTF?
Old Sep 27, 2003 | 07:21 PM
mmuller's Avatar
Mad Scientist
Default Re: 3rd gear grind. Need help please.. (Chiovnidca)
works better for grinding tranny's, just put it on mine even tough its good and it made a difference over honda mtf. it shifts beautifully
Old Sep 27, 2003 | 07:23 PM
HaUTSaauce's Avatar
New User
i wonder if his syncros are going bad?
Old Sep 27, 2003 | 07:44 PM
MachAF's Avatar
Default Re: (HaUTSaauce)
gm synchromesh manual transmission fluid !!
Its the ****! My 3rd gear syncro is trashed. Grinds big time. Put in syncro mesh. Only grinds at really high RPM. It use to grind at 3-4k rpm.
it makes shifting a lot smoother!....
Old Sep 27, 2003 | 07:53 PM
HaUTSaauce's Avatar
New User
sounds like good stuff
Old Sep 27, 2003 | 10:03 PM
Hybridize's Avatar
GM Synchromesh MTF =
Jdmglenn's Avatar
where can i go about buying this Gm sychromesh MT fluid????
Old Sep 27, 2003 | 11:02 PM
mmuller's Avatar
Mad Scientist
Default Re: (JdmGlenn)
gm or chevy dealership
Old Sep 28, 2003 | 08:46 AM
ultimatehonda's Avatar
Default Re: (mmuller)
Dont they sell it at auto part stores too?
Old Sep 28, 2003 | 09:24 AM
mmuller's Avatar
Mad Scientist
Default Re: (ultimatehonda)
no
Old Sep 28, 2003 | 11:46 AM
spooned out's Avatar
maybe your synchros are bad, mine grinded also so i switched trannies instead of fixing and you should tried different fluids maybe try synchromesh i heard everyones experience is positive.
Old Sep 28, 2003 | 11:59 AM
92 civic VX B18c's Avatar
HT Black Ops
Default Re: (Hybridize)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybridize &raquo;</TD></TR><TR><TD CLASS="quote">GM Synchromesh MTF = </TD></TR></TABLE>
It smells bad but works awesome! Makes your shifter feel like butter!
Make sure you get the GM Synchromesh, friction modified!
Old Sep 30, 2003 | 09:34 AM
Jdmglenn's Avatar
Default Re: (92 civic VX B18c)
OMFG i have a jdm S1 tranny with a 3rd gear that grinded all the time anywhere from 3g and up , but just recently put in GM sychromesh WOW , shifts like a new car and barely ever grindsL!!!
THANKS FOR THE TIP GUYS GM SYCHROMESH=
Old Sep 30, 2003 | 10:55 AM
I appreciate your advice guys and it looks like i'll be trying the GM syncromesh.
Econo Lube N Tune 1 Me 0
I took my car back today so they could put in Honda MTF (at no charge) They said it would fix it. Of course it didn't. I had the manager drive my car and he swears my clutch fluid needs replaced and I should pay 49.99 for it.. I'll do that myself.. but anyway. Would the clutch fluid be able to make ONLY 3rd gear grind? Or is it the 3rd gear syncro like everyone has said. I beleive it is the syncro, but recently I have noticed my clutch feeling much much softer. But then again, if It grinds at a high rpm 2 to 3 shift shouldn't it grind at a high rpm 1 to 2 shift if it's the clutch?
So what do I do now? Do I blame them for braking my tranny? Could the gear oil they put in have done it or is it just coincidence. He's assuming I race my car around town because I drove a honda.. So he thinks it's been thoroughly abused and won't believe what I say.
Old Sep 30, 2003 | 03:01 PM
VtecDA9's Avatar
Default Re: (Frosty18)
I think this GM syncromesh might be the savior for these b16 cable trannies wehre 3rd gear goes to **** frequently. I'll be using that on my next change and see if my 3rd gear 3-4g rpm grind goes way...
Old Sep 30, 2003 | 07:25 PM
T4eg's Avatar
Old Oct 3, 2003 | 11:57 AM
Muckman's Avatar
Moderator in Chief
Default Re: (BlueHatch00)
Are there any negative opinoins on GM Synchromesh MTF? A friend was saying its too thick if it can fix a grind and the thicker oil may lead to bearing or differential failure. Is this true?
jsen93ITR
Acura TL, RL & ZDX
Jul 14, 2008 01:59 PM
civiccoupe94
Nov 8, 2007 02:00 PM
meangreenEG
32
Jun 28, 2007 11:09 PM
t-town_ep
10
Apr 1, 2007 12:41 PM
civicmon
Aug 31, 2003 06:59 PM
