How do you remove the LOWER BALL JOINT ??????????????
Old Oct 1, 2003 | 03:55 AM
2camsaam's Avatar
Default How do you remove the LOWER BALL JOINT ??????????????
I am refering to the lower ball joint that is located behind the front brake rotor on the bottom of the HUB, it has a castle nut on it with a cotter pin that goes through it.
I tried beating it off with a hammer but no budge. What's the secret? I haven't been able to drive her since last Thursday.
Old Oct 1, 2003 | 04:51 AM
pro1342's Avatar
Default Re: How do you remove the LOWER BALL JOINT ?????????????? (2camsaam)
Are you replacing the ball joint, or trying to seperate the knuckle and LCA?
Old Oct 1, 2003 | 05:00 AM
2camsaam's Avatar
Default Re: How do you remove the LOWER BALL JOINT ?????????????? (pro1342)
I am trying to remove the lowerball joint.
Here is what I am trying to remove...
Old Oct 1, 2003 | 05:54 AM
ProfessorNate's Avatar
Still need to clarify... if you are trying to just get the spindle/hub/balljoint seperated from the lower control arm, then here's what to do.
Pull the cotter pin, and loosen the castlated nut. leave the nut threaded on just alittle, just to protect the threads.
Now hammer the SIDE of the LCA. There are little high spots on either side of lca in the balljoint area. This is where you are supposed to hit it. Do not hammer on the balljoint, which would damage the threads. I don't use 'pickle forks' either as they can damage the boots.
The ball joint shank is tappered, and the impact on the surrounding lca will pop the joint loose. (this is the same technique for most ball joints and outer tie rod ends)
NOW... if you already have the spindle/hub off the car, and are trying to press the ball joint out of it to replace it, that's a different issue.
Old Oct 1, 2003 | 06:26 AM
sackdz's Avatar
Default Re: How do you remove the LOWER BALL JOINT ?????????????? (ProfessorNate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProfessorNate &raquo;</TD></TR><TR><TD CLASS="quote">NOW... if you already have the spindle/hub off the car, and are trying to press the ball joint out of it to replace it, that's a different issue.
I think he's made it clear that this is what he's talking about... professor...
Old Oct 1, 2003 | 06:34 AM
pro1342's Avatar
There is a ball joint removal tool available, or it has to be pressed in/out.
Old Oct 1, 2003 | 08:39 AM
IN VTEC's Avatar
Take the knuckle ring off the back of the knuckle first, otherwise the ball joint won't be able to come all teh way up.
I've hammered it up and out before with a small sledgehammer with the knuckle still on the car, using only a jackstand for support.
If it really comes down to the last nerve, remove the entire knuckle assy and take it to a machine shop to press it out.
Old Oct 1, 2003 | 09:24 AM
jdmlsvtecrx's Avatar
do not use a pickle fork unless replacing the ball joint, they break the seal pretty easy..... if you tried using a hammer already ,,,, use a bigger one!!!!!
Old Oct 1, 2003 | 10:34 AM
5thgencivic's Avatar
Default Re: (jdmlsvtecrx)
I was able to get the one side seperated on my car but not the other side.. I beat on it with a 3lb sledge for a good 3+ minutes from all different angles. The only way it would have come off would have been with a puller so I had just dropped the arm(was replacing axle only). So you might need a ball joint puller if it doesn't separate. Mine was being a bitch
Aron Parsons's Avatar
Try a search. This has been covered numerous times, covering every possible way to do this.
Old Oct 1, 2003 | 10:53 AM
Baltz's Avatar
Default Re: (Aron Parsons)
I always use a pickle fork just make sure it isn't on the threads....then the bolt won't be damaged...
Old Oct 2, 2003 | 07:30 AM
PupaScoopa's Avatar
Default Re: (4th gen accord)
I've beat on mine for a half hour before finding an incredibly easy way to bust it loose.
Remove the cotterpin and castle nut.
Raise the suspension by hand or a jack.
Place a wrench between the LCA and Spindle, an 8" adjustable laying vertically works well... keep it clear of the boot.
Push/kick the spindle down
The "pop" sound means you can smile.
munoz86
Dec 4, 2008 03:59 AM
WPeters
May 17, 2008 07:09 PM
miguelv0723
Nov 11, 2006 04:26 PM
2camsaam
21
Oct 1, 2003 07:32 PM
Flamenco-T
Aug 21, 2002 11:49 PM
