2.0l b16 possible?
Old Sep 29, 2003 | 02:33 AM
quik sol's Avatar
Default 2.0l b16 possible?
whats the biggest displacement I could get out of a b16? (resleeved of course) and what kind of bore would I be looking at to accomplish this or atleast close to it. Thanks any additional information about this topic that I didnt ask would be great!
Old Sep 29, 2003 | 05:28 AM
TimoneX's Avatar
New User
Default Re: 2.0l b16 possible? (quik sol)
Lessee here. If you were to bore to the max(86mm) then you'd get to 1.8l(1789cc). If you then swapped the crank & rods to B17 parts you'd be at 1.9l(1898cc). A B18c crank would put you at 2l(2026cc), but the engine would have ugly ugly geometry. I'd say stick with sleeving and then if you want a bit more torque locate a B17 crank & rods set. There's an interesting write-up on this very setup at:
http://www.hstuners.com/news/wmprint.php?ArtID=33
Old Sep 29, 2003 | 01:34 PM
inspyral's Avatar
Would a B18C crank work with the lower B16A deck height? Maybe you can look for a cheap B18A/B block to sleeve, since an 84mm bore on one of those will put you at 2.0L. Or maybe a blown B18C, or a B18C with an LS crank/rods
Old Sep 29, 2003 | 01:43 PM
Katman's Avatar
Default Re: 2.0l b16 possible? (TimoneX)
I have an immaculate repolished & checked B17 crank for sale $350 (not shipped), if any ones interested in one. I don' the rod tho sorry.
Old Sep 29, 2003 | 01:55 PM
TimoneX's Avatar
New User
Default Re: (inspyral)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Would a B18C crank work with the lower B16A deck height? Maybe you can look for a cheap B18A/B block to sleeve, since an 84mm bore on one of those will put you at 2.0L. Or maybe a blown B18C, or a B18C with an LS crank/rods </TD></TR></TABLE>
Yeah with custom rods. I wouldn't care for the resulting r/s ratio, but Crower even makes an 89mm stroker kit for the B16. Now that seems like it'd be really ugly. Since the original question was specifically in regards to the B16 I limited my response to that block.
Old Sep 29, 2003 | 04:46 PM
b20_ed's Avatar
Default Re: (TimoneX)
somebody on the board has a 2.1 liter b16! cant remember his name though...
Old Sep 29, 2003 | 05:06 PM
TimoneX's Avatar
New User
Default Re: (b20_EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20_EK &raquo;</TD></TR><TR><TD CLASS="quote">somebody on the board has a 2.1 liter b16! cant remember his name though... </TD></TR></TABLE>
I had a discussion with allmotorb20vtec just the other day. He says he has a b16 with an LS crank. Didn't comment on bore size however. He did imply that it wasn't very reliable, as you'd expect given the piston side loading.
Old Sep 29, 2003 | 10:42 PM
gamakichi77's Avatar
u can go for 87mm bore and 95mm stroke which is increase ur displacement to 2.26L. This spec you can buy it from CROWER. But need sleevings. U can sleeves ur blocks at Golden eagles. Hope u enjoy with its power.
Old Sep 30, 2003 | 12:59 AM
quik sol's Avatar
Default Re: (acidburns_di)
I dunno, I dont wanna do a stroker kit because people say there really unreliable and since my car will be raced probly once a week at the local track. I need reliablility for the drag racing AND enjoying my car on the weekeneds. No its not my daily driver but I still like to enjoy my car on the weekends.
Old Sep 30, 2003 | 06:44 AM
TimoneX's Avatar
New User
Default Re: (quik sol)
You won't get to 2.0l w/ a b16 w/o stroking. Converting your engine to a b17 w/ the parts I mentioned prevously increases stroke from 77 to 81.4mm. This retains a r/s ratio of 1.625:1 which is still higher than a B18c at 1.58:1. This setup combined w/ 86mm bore is the max displacement you can reasonably squeeze from a daily driven b16 w/o killing reliability.
viperjng
36
May 2, 2011 07:20 AM
runitup
Mar 1, 2003 04:22 PM
ekekek
Feb 7, 2002 10:00 AM
I-VTECRX
Jan 23, 2002 04:58 AM
Jimmy L
Oct 15, 2001 10:20 AM
