best shocks
Old Sep 26, 2003 | 08:22 AM
wm5holla's Avatar
Default best shocks
Koni ''Red'' Shocks ::: KONIs are not the average shock absorber, they feature a number of standards that make them unique:
KONIs are adjustable, which means that you can influence the behavior of the car to meet your preferences (ride comfort, handling balance, etc.). It also means that wear can be compensated. They are designed for a specific car or even special driving conditions. A KONI is not a simple copy of the original but a tailor made design to get the best handling and ride characteristics from the vehicle.
KONIs improve the ride and handling of your car. The damping characteristics are developed for each particular application. Koni's specialists keep on testing and modifying until they are convinced they reached the optimum in both handling and comfort.
<hr> Koni ''Yellow''
KONI Sport dampers are externally adjustable by means of a ****, so they need not be disassembled from the car. The fine-tuning of the damping forces to personal driving style and to different driving conditions takes a matter of seconds. The best of fine-tuning technology straight from the world of Formula 1 racing. KONI Sport Dampers serves sporting drivers with a carefully designed range adjustment ranges and ride comfort. This line focuses on exceptional road-holding and handling properties, combined with an acceptable level of comfort.
KONI Sports improve the ride and handling of your car. The damping characteristics are developed for each particular application. Koni's specialists keep on testing and modifying until they are convinced they reached the optimum in both handling and comfort.
Along with a lifetime manufacturer warranty, these shocks are some of the best deals around.
Sport ''Yellow'' Shocks come with adjustment **** for easy adjustment on the fly.
<hr> KYB AGX Adjustable ::
AGX Adjustable Gas Shocks and Strut Cartridges are for the driving enthusiast who owns a sports compact, sports coupe or sports car. KYB AGX shock absorbers allow easy adjustment of the shock damping rate to tune the vehicle’s performance to meet the needs of the street, strip or track. KYB AGX Adjustable Gas shock absorbers are externally adjustable, so there is no need to disconnect or remove anything to change settings. Depending on the vehicle’s configuration, the damping rate is selected with an external **** on the side of the shock body or through a screwdriver inserted into a slot at the top of the strut’s piston rod. The KYB AGX shock absorber’s single damping adjustment changes the shock’s compression and rebound resistance at once. When you want adjustable high performance control, you want KYB AGX Adjustable Gas shock absorbers.
Tokico blues HP Performance shock absorbers and struts improve cornering, braking, steering response, and overall stability. They also reduce excess body motion while giving a good ride. All prices are for a single shock.<hr>
Tokico Illumina Shocks Illumina five point adjustable shocks and struts provide the same quality as the Premium Performance, but with the extra dimension of adjustability. The ease of adjustment allows the vehicle owner to change the handling balance of the car for everything from daily driving to autocross or even drag racing. All prices are for a single shock.
Old Sep 26, 2003 | 08:25 AM
wm5holla's Avatar
Default Re: best shocks (wm5holla)
i really adjustable shocks!
i need to knowwhat better yellows or reds or kyb
Old Sep 26, 2003 | 03:11 PM
NonovUrbizniz's Avatar
Loved
yellow's are better... they are adjustables...
the reds are still probobly better than the kyb's...
Although I have nothing agains kyb's... I had gr2's in my last car for over 80k miles... and they were AWESOME... I BEAT that car too... REAL hard. never gave me any problems.
Old Sep 26, 2003 | 03:26 PM
wm5holla's Avatar
Default Re: best shocks (NonovUrbizniz)
reds and yellows are both adjustables
Old Sep 26, 2003 | 04:33 PM
Eyewitness's Avatar
Yellows are alittle extreme IMO.....i cant justify the price....kybs are fine for me...maybe some reds
Old Sep 26, 2003 | 04:42 PM
djtriptronick's Avatar
They are alright!
Old Sep 27, 2003 | 12:02 AM
kill bill's Avatar
Default Re: best shocks (djtriptronick)
penske
Old Sep 29, 2003 | 11:46 AM
Pete_SI's Avatar
With these shock and coilovers do you need anything else to put them on?
Old Sep 29, 2003 | 12:44 PM
Littleton's Avatar
Default Re: best shocks (Pete_SI)
Penske only makes racing shocks for Honda's for IRL and F1.
JIC makes the best shocks/dampers for Honda's. Zeal is a close second. Moton is the sh*t but I don't think spending 7k on a set is worth it.
LogicMotorsports.com
263
Oct 9, 2012 09:54 AM
hawk2828
Suspension & Brakes
Jan 21, 2010 04:45 PM
prostreetonline
Jul 18, 2004 04:55 PM
daewonder.
Nov 5, 2003 03:51 PM
