can the clutch only cause one problem?
Old Sep 28, 2003 | 09:06 AM
ludelvr's Avatar
Default can the clutch only cause one problem?
Can the clutch only cause slipping or are there other problems that can be associated with the clutch? For example, not getting it into gear?
Old Sep 28, 2003 | 09:42 AM
mmuller's Avatar
Mad Scientist
Default Re: can the clutch only cause one problem? (ludelvr)
bad pressure plate, clutch springs, pilot bearing would make shifting hard or not possible.release bearing would make the infamous helicopter noise.
glazed clutch disk or flywheel could cause clutch chatter.
thats all i can think for now.
Old Sep 28, 2003 | 11:02 AM
TimoneX's Avatar
New User
Default Re: can the clutch only cause one problem? (mmuller)
Like he said there are several things to go wrong with a clutch, each has different symptoms. My LS was recently refusing to go into any gear unless at a near complete stop, and making clicking sounds when it did. I suspected it was the throwout bearing and sure enough when I got it apart the bearing was in 3 pieces, the disc was fine however looked like it had thousands more miles to go. I replaced everything however.
Zteve
Nov 18, 2009 08:46 AM
petty$rep
Oct 31, 2006 08:45 PM
vlc92189
Aug 30, 2006 11:10 AM
SIKING
Oct 12, 2003 05:29 PM
