Smoking problem
Old Sep 27, 2003 | 09:34 PM
KillerBee18's Avatar
Default Smoking problem
Ok my car was smoking a ton and oil was everywhere. No oil in IC pipes and turbo was not blown. I thought it was the head gasket and just changed that out. But the smoke is still coming from the valve cover if i have the oil cap off when the car had just been ran. Oil is not sparying everywhere yet cause i have not really reved high. car idles really low before and after i replaced the head gasket i put the timing on full retard cause i need to get a timing gun (and still idles low after head gasket changed, but could be because of timing) Help
Old Sep 27, 2003 | 09:51 PM
K20EG's Avatar
Default Re: Smoking problem (KillerBee18)
it sounds like you need to change the valve cover if it was leaking from there
if your oil dipstick pops up under power ...and shoot out a lil oil ...that could cause that kinda smoke to
Old Sep 27, 2003 | 09:58 PM
smoke is coming from the valve cover if i take off the oil cap after the car has been ran. and the oil seems like it was coming from the back on the throttle body side
Old Sep 27, 2003 | 10:00 PM
K20EG's Avatar
it could be the pcv box chingas on the back of the block ?
maybe the other chingas is unplugged from the box
Old Sep 28, 2003 | 08:49 AM
let me try that. any other suggestions??
Yodi71
14
May 11, 2014 01:50 AM
jakop92
Nov 15, 2009 11:33 AM
keilux
53
Aug 17, 2009 05:43 PM
90CivicDaily
12
May 4, 2008 10:12 AM
Asahi
Feb 2, 2003 05:24 PM
