Is my gsr block salvageable
Old May 24, 2009 | 05:50 PM
dc2_97teg's Avatar
Default Is my gsr block salvageable
Just a few weeks ago i spun a rod bearing. So upon taking off my oil pan to inspect it i found tiny bits of copper shavings from the bearing. I know for sure my crank is done on the journal on cylinder 2 but i wanted to see know if my block was still salvageable, if not i was planning on picking up an itr block. But i don't want to spend money, so if its worth fixing please give me some input... also in the first two pics its right above the crankshaft at bdc on cylinder 2
edit: sorry for the blurry pics, i am not accessible to a decent camera, so i used my phone camera.
Old May 24, 2009 | 07:06 PM
KWayRacing's Avatar
Default Re: Is my gsr block salvageable
block is salvageable fir sure
Old May 24, 2009 | 07:21 PM
dc2_97teg's Avatar
is it safe to run with a new crank shaft. or should i take the block to a machine shop to get it resurfaced?
Old May 24, 2009 | 07:51 PM
thumper64's Avatar
If it's just a spud bearing, get a new crank, bearings and rings and you should be fine.
LS cranks will fit, if you remove/mod oil squirters.
Old May 24, 2009 | 07:59 PM
dc2_97teg's Avatar
yea i thought about the ls crank. but most likely im debating about eagle, itr, or gsr crank. but my main question is in the first 2 pictures. is my block still usable or would it be safer to get a new one?
Old May 24, 2009 | 11:04 PM
stevenDAtegra's Avatar
Your block is still going to be good. Just make sure you get your clearances correct with the new crank and bearings so you won't have to do it again
Your phone takes alright pics though
Old May 25, 2009 | 01:56 PM
ITR-EKcoupe's Avatar
looks like your rod hit the bottom of the sleeve. same thing happened to my block when the rod spun. took it to a machine shop they bored it .5 over, new pistons rods and she was tip top. you'll probably want a new oil pump aswell because of the shavings.
Old May 25, 2009 | 09:42 PM
dc2_97teg's Avatar
you think .5 over would clear that? and yea i figured i would nee an oil pump... i have so many shavings in there.
Old May 26, 2009 | 05:26 PM
dc2_97teg's Avatar
does everyone else agree that this block is salvageable?
Old May 29, 2009 | 02:57 PM
the only reason id bore it is to freshen the motor up and debur those bottom cylinder scars. not too sure what your cylinders look like. but for under a grand (pistons, rods, crank etc..), to have a rebuilt motor seems like a good idea to me. im sure you could go the cheap route an do half of those things and make it work. but i like doing things the right way the first time.
Old May 29, 2009 | 02:59 PM
definately salvageable. probably want to find out why it blew up in the first place tho. just so it doesnt happen again.
sitinduk
Sep 2, 2010 05:08 PM
2ndgenteg-md
Apr 11, 2008 01:07 PM
tracetec2000
Northeast (Sales)
Aug 4, 2006 01:27 PM
SLOW4drINTEG
Jun 9, 2003 09:53 AM
ASHY-ELBOW
May 11, 2003 09:20 PM
