lost motion assembly
Old May 15, 2009 | 04:14 PM
vu337's Avatar
Default lost motion assembly
hi guys, if i don't change the lost motion assembly because of noise will it affect anything
how excactly do u check to see if they are still good
i change them out to another used set and still that ticking noise but when u rev it it goes away, its loud at idle?
Old May 17, 2009 | 02:32 PM
nukefivesix's Avatar
Default Re: lost motion assembly
yea i have the same problem.. any ideas?
Old May 18, 2009 | 04:20 PM
vu337's Avatar
i think it's the lma cause i put another used set in it but with the same noise , i will get the newer version ones with the spring for the lma
Old May 19, 2009 | 04:31 AM
mmuller's Avatar
Mad Scientist
besides feeling their movement to be smooth all through its stroke, you can rev the engine to at least 3k rpms, listen to the bad sound; give the vtec solenoid 12v to engage vtec. see if noise stops
Old May 20, 2009 | 06:50 PM
vu337's Avatar
i will try that but what am i looking for when i give it power , to the one wire vtec solenoid?
Old May 20, 2009 | 07:16 PM
JNocon's Avatar
I had the same problem, too. First, I thought it'll be the valve clearance issue, so I adjusted my valve lash. But, the valves were quiet. Then, I end up opening it again. Then, I checked the lost motion, it was pretty loose, so I took my extra set from my other head. Put it back, adjusted the valve lash again, and the noise was gone.
obuhmyuh
Feb 2, 2008 12:00 AM
B20BV
Dec 14, 2007 11:55 PM
Azxster
Oct 27, 2007 06:02 PM
94LSVtecTeg
Aug 10, 2003 08:06 PM
whatcivic
Jun 6, 2003 07:13 AM
