whole gauge cluster doesnt work...help!!
my speedometer needle, rpm needle, trip meter, gas and hot and cold needle. the only thing that's working are the lights on the cluster.
Have you checked the "METER "fuse, fuse 25 - 7.5A, [hot in run and start] in under dash fuse box.
don't just eyeball it test it or replace it with a known working, [or new] one.
You should also test for power at the fuse when ign. switch is in the run position.
If you have pulled your cluster for any reason before you had this problem, and fuse is good, pull the cluster and make sure the harness plug(s) is plugged in properly. 94
there are about 10 of those 25 -7.5 fuse. which one am i suppose to replace? my sensor is connected. there are suppose to be only two wires with the green clips that connect to the back of the cluster right? one that connects to the top of the cluster and on the side.
There is only one fuse 25, [fuse number 25] it is a 7.5A fuse, it is in the under dash fuse box.
There are way more then two wire, but yes there are two "multi wire" plugs that plug into the back of the cluster. 94
i have two green wire clips, one yellow wire and one orange wire clips but can't find where the orange one go to. i believe the yellow wire is for the air bag light.
