headgasket shopping
hell yeah what else do I need for a headgasket change
cam seals...
I have new arp stud in the head now do I need to replace these as well the engine doesnt even have 10k on it yet
cam seals...
If you wanna be safe replace all seals from things you took off
*Intake Manifold Gasket
*Exhaust Gasket
*Cam Seals
*Valve Seals if you want
*Vtec Solenoid Gasket
Just some things you could do
*Exhaust Gasket
*Cam Seals
It's all really easy but there are probably write ups.
Do you have a haynes or helms manual? For getting the head off you just take off the intake manifold(possible to leave it on but it's harder), take off valve cover, loosen timing belt tensioner, slide belt over, take cams out and then remove the headbolts securing the head. There is an order you have loosen the bolts though which is from the outer headbolts towards the center. When you torque it down, torque from the center and out and this will make sure your head doesn't warp.
i need to pick up a haynes manual then... I just afraid of taking the cams out be cause I dont wanna **** up the timing with my turbo cuz im sure 1 degree off can cause a catastophic failure
deerman2701
Feb 1, 2013 05:33 AM
