what bolts for itr lcas?
i just got some tanabe sustec coilovers. my boy said that the rear lcas use different bolts than the ones i have now. i have a 95 integra rs. do i need the bolts for the itr lcas?
I don't think the ITR or non-ITR shock bolts are significantly different in length.
What rear LCA's do you have? ITR or non-ITR?
What chasis were those Sustec's made for? ITR or non-ITR?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">I don't think the ITR or non-ITR shock bolts are significantly different in length.
What chasis were those Sustec's made for? ITR or non-ITR?</TD></TR></TABLE>
i have itr lca's and the sustecs are for an itr.
Bolts are more than likely the same size b/w the two. I can't find anything about the GS-R ones being longer.
If you need bolts, go to the hardware store and pick up a pair of grade 8 or grade 10 M10x1.25x89mm flange bolt. If they don't have that length in a flange bolt, then pick up some washers too.
i was thinking about just going to the acura dealership 5 mins from my house and grabbing some stock **** so that i'm sure everything will fit right.
Paul1985
Suspension & Brakes
Jul 4, 2006 06:58 PM
